Looking for wiring manual for Hot Rod Air Inc. - Elite Standard Air Conditioning Unit
ACTECH
  • 80 Answers
SOURCE: split air conditioning system, evaporator
CHECK THE COIL ON YOUR CONTACTOR TO SEE IF YOU HAVE 24 VAC
CHECK YOUR BREAKERS MAKE SURE THERE NOT TRIPPED AND LET ME KNOW
Posted on Jul 22, 2008
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
FunnyPlumber
  • 43 Answers
SOURCE: The other day. my American standard air
Yes, that might be the problem but in this case you need a qualified technician to test system and find real cause of problem.
Posted on Jun 24, 2009
  • 116 Answers
SOURCE: my air conditioning blows hot air only, nothing
ok if unit is split system two piece check to see if out door unit is running fan and compressor the air coming out of the fan should be about 20 deg warmer than out door temp if not compressor not running check the capicitor to see if swelled up on top if so bad if unit has electric heat strip a heat relay may be stuck and you are running aug heat to check this pull disconect on out door unit and see if heat is out of vents if heat pump reversing valve may be bad hope this helps
Posted on Jul 04, 2009
Thermo King
  • 593 Answers
SOURCE: I'm looking for a manual for a Goodman HG31ES air
Go to this site and join w/ your email - download the manual you want for free
http://portablemedia.manualsonline.com/manuals/mfg/insignia/ns-4v17b.html
Posted on Jan 21, 2010
A/c blowing hot air with low pressure
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
Jul 09, 2013 | Cars & Trucks
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
I'm looking for a manual for a Goodman HG31ES air conditioning unit. Anyone have a suggestion?
Jan 19, 2010 | Goodman Heating & Cooling
Looking for elec. wiring diagram Armstrong unit pge10a42d100a-3a
Google Lenox and you will get armstrong also. The have tech site for diagrams and instructions.
Nov 28, 2009 | Heating & Cooling
My air conditioning blows hot air. Won't accept
Is the system low on Freon? If not, you most likely have a bad A/C compressor, or a bad low pressure switch.
Jun 10, 2009 | 1998 Ford Mustang
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
