Question about Fast Lane Toys
Instructions for long bridge challenger 2 - Fast Lane Toys
Can i get personalized garden bridges?
Yes, you can either request a customized garden bridge from garden bridges' shops, designers, websites etc. Or you can ask someone with some skills in the woodwork field to make one for you following garden bridge instructions from the web, and your own instructions for the customizing
Jan 08, 2014 | Garden
Need instruction manuals for thomas the train shake shake bridge and midnight ride.
Here is how Shake Shake bridge goes together:
On the bottom of each piece is a letter. Here is how the letters fit together to form an oval. Bridge is A and the other straight track is F you also have 2 B's & 2 C's
going clockwise: A - B - C - E - F - D - C - B
The 2 tall supports go under the junctions at B & C on either side and the small supports go under the junctions at C & D and C & E
Jan 26, 2011 | Toys
Jl audio w7 13 subwoofer system 3ohm driver bridge it 2 ch amp
How much is your speaker max wattage?
If it is 750 or below, it can only be used on one channel, either the right or the left.
If speaker can handle 1500 watts then hook the positive speaker wire to R+
Hook black negative speaker wire to L-
Now it is bridged
Aug 19, 2009 | Jl Audio 13W7 Car Subwoofer
Kicker 8 inch 4 ohm subwoofer 200 watts rms?
Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
Don't get a mono - most are 300W or more - might burn the coil during loud passages.
Jun 22, 2009 | Car Audio & Video
Trying to pull out the board that mounts the STK392-110 convergence parts and resistors but having problems disconnecting the 4 white connection that bridge the two boards together. Also problems with...
I suffered the same challenges. The bridge clips simply snap into place on the board with the convergence parts . To separate the bridge, I simply put a small screwdriver under the clip and gently pryed up close to the base. The spark plug type wire can be removed by wrapping the wire with electrical tape (with the boot moved back ) grasping the wire with needlenose pliers and striking it quickly. They are pretty stubborn,but this worked for me. Hope this helps
Mar 27, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Peavey 1200 Amplifier
Some of the outputs transistors is bad hence causing a bridge in circuit,thats why the fuse is blowing.Check all the outputs transistors on both channels,rectifiers and zena diodes these are the possible causes of circuit bridge when they are faulty.The fan works on AC thats why it is not affected even when the fuse is blown.Please if you have anymore challenge please send me a mail on mikewee4wee@yahoo.com
Aug 14, 2008 | Audio Players & Recorders
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Aloha
Bob
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Toys Logo
106 people viewed this question
Top Fast Lane Toys Experts
Shekar Avadhani
Tom Chichester
Are you a Fast Lane Toy Expert? Answer questions, earn points and help others
