Question about Fujitsu 18C1 Air Conditioner
Fujitsu AOT 24 RZL
Long distance compressor repair. Can i x-reference compressor model to outdoor unit model
  • 2,071 Answers
Fujitsu asta12lcc timer flashes 5 times
From the service manual:
Serial forward transfer error during the operation
When the outdoor unit does not receive the signal for 10 consecutive seconds during the operation > Outdoor unit stops.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
Jan 17, 2017 | Fujitsu Heating & Cooling
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
I have a trouble with fujitsu outdoor model AOY30LMAW4,indoor run but outdoor dont work,every sensor,board is ok,and i dont know how to do next,help me please !! Thanks so much
THE UNIT HAS TO HAVE 2 DIFFERENT VOLTAGES TO RUN.. 24 VOLTS FROM THE THERMOSTAT TO THE CONTACTOR MUST BE PRESENT. REGULAR LINE VOLTAGE TO THE CONTACTOR. FROM THE FUSEBOX OR THE DISCONNECT
May 05, 2015 | Fujitsu Heating & Cooling
Hi I have a problem with my Fujitsu wall mounted air conditioner ,model AST24RGB-W the outdoor unit fan is running but there is no cold air coming out from the inside unit I put it on high cool to get cold...
I think, your compressor is not working. Check with amphs meter. If less amphs gas leak. Arrest the leak and re charge gas. If tripping with high amphs change capacitor. Still high amps, compressor is defective.
Dec 26, 2010 | Fujitsu Heating & Cooling
I have a fujitsu twin head air con that is at least 10 years old the external compressor is not turning on but it does work my fridge mech was not sure of problem but thought it was the control board not...
The outdoor PCB has a series of led's on it which indicate the status of what is operating. If the lights are on and nothings working then you will need a new outdoor pcb which is only availible from fujitsu.
Jan 09, 2010 | Fujitsu 18C1 Air Conditioner
Fujitsu a/c ast24rsg-w blows fuse after 3 mins as comp starts up
It sound like you have a direct short in the compressor ,Usually it means you have a bad compressor,but sometimes it could be a loose wire or bad outdoor motor. Ive installed about 10 of these units and still have yet to have a bad compressor.It could also be a bad circuit board in the outdoor unit.I wish I could narrow it down better but thats my best guess!Thanks ---Nate
Jul 14, 2009 | Fujitsu 24R1 Air Conditioner
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Fujitsu general ars40 duct type
you have to clean your A/C unit, indoor and outdoor, be sure all frost are de frosted before you run your unit again, or else it will frost again. if this not work your unit need re-gassing.
Jan 20, 2008 | Fujitsu 24R1 Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
308 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
