Question about Canon PIXMA MP970 InkJet Printer
Error 6A00 on the Canon Pixma MP970 - Canon PIXMA MP970 InkJet Printer
    President:
  • 287 Answers
Hello and Welcome
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MP970 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
I hope it will be surely helpful for you. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs given below to this solution if it was helpful.
Thank you for using FixYa
Posted on Mar 12, 2011
bschilz
  • 2049 Answers
SOURCE: Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Posted on Apr 29, 2010
  • 240 Answers
SOURCE: Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on May 19, 2009
  • 6 Answers
SOURCE: will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
Posted on May 30, 2009
  • 18 Answers
SOURCE: canon pixma ip 3000 6A00 error
the error on this printer relates sheet feeder and or the logic board or the purge unit tin the printer if one of these items fails in the printer it causes this error the printer needs to be takewn to a canon service agent in your area for repairs the error can notbe fixed by the user. It class a a service error on the printer
Posted on Dec 04, 2007
komguy
  • 2306 Answers
SOURCE: canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Posted on Jul 24, 2009
6A00 error code
6A00 is a problem with the sheet feed unit. I would get in touch with Canon, to hopefully get it repaired. Not much you can do yourself sadly.
Nov 22, 2012 | Canon PIXMA MP830 All-In-One InkJet...
Says there is an error 6A00 am trying to replace magenta cartridge
On this site there is a solution for your problem.
The solution is meant for Canon IP4300, but can be used for Pixma MP830 as well.
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Regards
Sep 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
The copy shows a error code 6A00 I can't do anything with it the ink cradle does not light up
Solution Canon Pixma IP4300 Error 6A00, this reset tips is from someone in printer forum but the tutorial in picture. You can follow the instruction in the picture to solve error 6A00 in Canon iP4300. Some users say on the forum this reset method also work on Canon iP4200 and Canon MP800. Look the picture below to view the complete tutorial how to solve Error 6A00
Larger picture here
Jul 07, 2011 | Canon Office Equipment & Supplies
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
My Cannon has an error code 6A00 what does this mean, ? I have turned it off and on a couple of times, but nothing has changed. Thank you Regards Mike
If you get a 6A00 error it means something is stuck in your printer...it could be a clogged printer head or a paper stuck. Try checking your printer and moving the tray from right to left manually then put it back to the right then test it again.
Thanks!
mannu_rakesh
Aug 17, 2009 | Canon MP970 Photo All-In-One InkJet...
Canon pixma mp800 error code 6A00
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Will not turn on error 6A00
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA MP970 InkJet Printer Logo
3,157 people viewed this question
old marine
old marine
