Question about Kenmore 74252 / 74254 / 74259 Top Freezer Refrigerator
Ice cubes Hollow, Frost on back wall just were cold are goes to frig side, and water in the frig.
  • 4,070 Answers
The frost is probably a defrost problem. Hollow ice is caused by not enough ice in the ice mold.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. There is a screen mesh filter in the water line where it connects to the water inlet valve which may be partially stopped up. The valve is where the water supply from the house connects to the fridge.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Mar 12, 2011
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Ice is melting in the ice container.
Step 1:
You could have one of several problems with this unit. Do you have heavy frost on the back wall of the freezer? If you do then you have a defrost problem. You might need to replace the defrost t-stat on the evaporator.
Step 2:
If that is not the problem then you might have a dirty condenser. Check the dividing wall between the refrigerator and freezer, is it hot? If so, clean your condenser and make sure the fan in the back is running.
Step 3:
If that is not the problem then you might have a water supply issue. Are the ice cubes hollow? It might be just a water filter that needs to be replaced. Your ice maker might be dripping water as well, if you see ice cycles hanging from the ice maker then the ice maker needs to be replaced.
Step 4:
The worst would be a freon leak... To check this remove the evaporator cover in the freezer and look at your frost pattern on the evaporator.
Good frost:
That is a normal frost pattern on an evaporator and everything is good.
Bad frost:
That shows a freon leak and you would need to call a qualified professional to complete this repair. This can get expensive so think if it might just be better to replace the unit.
Good Luck!
Mar 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a Kenmore, side by side, with ice cubes-crushed-and water, color-black. My problem started with the refrigerator side not being very cold, now the freezer side is not freezing. The fan is blowing...
you said a lot . the frost in the freezer back would let know that you have a defrost problem . no frost means no frost . so the heater or the terminator have failed . the unit needs to be defrosted of ice and the heater cked and if bad replaced and always replace the terminator . orthe cause is the a d c adapitive defrost control . ,, mm
Aug 20, 2010 | Kenmore Refrigerators
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Making hollow ice cubes
Hollow ice is a sign of not enough water going into tray . Replace the water inlet valve (piece that the wall water line connects to on refrig ) .
Aug 29, 2009 | Refrigerators
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 74252 / 74254 / 74259 Top Freezer Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
