Have a kenmore 400 washer and just want to know what i can do about the drain pipe filling to the top and haveing toshut off the washer let it drain and start again
  • 4,070 Answers
There is likely an obstruction in the drain pipe of your house. You'll have to clear it out.
Posted on Mar 12, 2011
I have a Kenmore 60 series washer that will not fill, water runs right out drain, why?
Your drain pipe it's too low. It needs to be a certain distance above the ground.
Jun 08, 2014 | Kenmore 24032\24036 Top Load Washer
My washer will not hold water. When it is set to fill, the water runs out of the machine in the drain pipe.
you have a graffity problem, make sure that the drain pipe is lifted above the tub level tie it with a strap or a tie
Sep 02, 2011 | Kenmore 22422 Top Load Washer
My used Kenmore washer fills with water then the water level drops downto about the half way level in drum. I just bought it used and installed it yesterday. Could the water be siphoning out into drain...
It sounds as if it is siphoning out the drain pipe.You have to get the drain pipe up to the top of the washer and also be sure that the pipe is a little bigger than the drain hose or it will siphon. Hope this helps.
May 13, 2011 | Kenmore 24032\24036 Top Load Washer
Machine is draining as it fills, can not rinse due to this. What may be causing this?
If the drain hose is laying down then the water will flow out as it fills. The drain hose should empty into a 2 inch drain pipe that is about as high as the top of the washer.
Jun 24, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore model 110 top loading washing machine that keeps draining and wont fill up but sometimes it does and sometimes it does not. Help!
Your drain hose is too far down into the pipe behind the washer. What's happening is your drain hose is actually siphoning water from th washer the same time its trying to fill up. Pull the drain hose up from the drain pipe and secure it so its doesnt fly out when the washer is draining. Check too see if the problem goes away. If not pull the drain hose out more repeat steps.
Feb 17, 2010 | Washing Machines
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
I have a kenmore 80 series washer and it won't fill up some times
It sounds like a siphon issue so nothing should be broken.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer fills and spins at the same time
If the washer has been recently moved the drain hose may be too far down the stand pipe causing a siphoning effect
Jun 11, 2008 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
