When the heater is switched on to 1, cold air comes out instead of hot air. Also, when switched on to number 2, there is a burnt smell coming from the heater.
    Master:
  • 403 Answers
Sound to me that the t-stat is no good on the unit. get yourself a multimeter and chech the resistance in the different locations on the switch. you should be able to get the specs at the heater companys website
Posted on Mar 12, 2011
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
Aug 16, 2014 | 2008 Chrysler Sebring
Smell of antifreeze and heater blowing cold air in my 97 eclipse
Check heater core location for leakage. If no heat is coming out when you have the temp set to hot, chances are you have a blocked heater core. If you smell antifreeze from heater fan, you may have a leak in the box that contains the heater core. Your windows may fog up too, if you keep the heater on for a bit, but this happens more often if the air coming out is warm, or hot. Hope this helps!
Oct 03, 2013 | 1999 Ford Taurus
Need hot air to come out of heaters blowing good air flow but not hot and its getting cold
2 things it could be,is the thermostat is staying open,not letting the coolant get hot or the heater core is bad,any water on front floor board on driver side or a funky smell.
Oct 26, 2012 | Cars & Trucks
Smell gas when I turn on the heat
Contact your emergency gas people ,you have a serious problem and if left can kill,seek professional assistance now.
Jan 20, 2018 | 2004 Chevrolet Impala
Why is my air conditioner trowing hot air instead and is brand ne
mcdevito75 here, You may need a charge of freon gas to make the A/C Cold, secially if your A?C unit hasn:t been serviced in 2--3 years. alo chech switches on the unit Fan on 3 Minutes, then Low cool and 1/2 way thru the blue scale shown on the knob. If all is set well, see your local A/C repair shop., they come to the house.
Jun 24, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Blowing cold air instead of the heat
Heater coil has possibly burnt out. his coil is located rightr behing the front coil of the a/c You need to pull the unit from its sleeve and look inside behind the a/c coil and there it is. It looks like the inside of a toaster the elements should be incased in a metal box. What causes the burn out is 1 poor air flow over coils due to dirty filter or dirty coil, 2 dust build up, the minute particals the get through the unit 's filter and build up over time causing burnout, 3 possible high limit switch on the coil housing itself. This switch prevents the heater from overheating and causing a fire. Have this look at by a tech the cost incurred isn't really that much.
Good luck on your repair hope this helped
Dave
Dec 10, 2009 | Frigidaire FAC126P1 wall/window Air...
Overheating, guage not over 1/2 mark, overflow smells like exhast
Have you tried running car from cold, with rad cap off, & heater turned on, coolant topped up, an inch or 2 from top of rad? Let it run up to operating temperature, cooling fans kick in & out 2 or 3 times, and top up coolant as needed, then put rad cap back on, & fill return bottle up to mark. There may be a worse problem, but bleeding system as I have described, ensures all air out of heater core & cooling system, which has been cause many times before on all makes & models of vehicles. Especially when no heat situation. Let me know if it helps.
Jul 12, 2009 | 2000 Jaguar S-Type
Heaters dont work on my mk3 golf cabrio
if the blower motor is gone u will get no air cold or hot.
If it is the switch you would hear the blower but maybe get no hot but just cold air or vice versa.
Jan 07, 2009 | 1996 Volkswagen Golf
Ac warm air not working
1 do you have water in the radiator.2 could be your heater core .3 or where your controls are hot/cold could be just a simple plug or cable came loose and not letting it switch from hot to cold or visa versa.when you pull your switch from left to right or right to left.dos it fill easier to switch .if so it might just be a broken cable.if none of the above 3 help your problem then it could be your thermostat sticking a common problem.if it was me i would try number 1 then number 3 then the thermostat.and last the heater core .do the simple ones first.i hope this helps thanks jeff
Nov 29, 2008 | 1992 Honda Civic
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
