Question about Garden
Gun has no air leaks,when you shoot it it sounds like it is nailing but no nail comes out. It is a framing gun,4 yrs. old or so.
    Scholar:
  • 158 Answers
Sounds to me like it needs cleaned and oiled. If it has been unused for 4 years the rubber orings are most like in need of replacement also.
Posted on Mar 12, 2011
  • 10,865 Answers
Hello hunt..... oil it and also check to be sure that the nails you are using are the correct ones for that gun, and that the air pressure is set high enough.
Finally disconnect it from the air supply and manually raise and lower the "hammer" to properly lube it. Joe
Thanks for choosing Fixya!
Air comes out the nose of my dewalt framing nailer
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
Dec 07, 2013 | Dewalt Air Tools & Compressors
My airace framing air nail gun blows air when i try to shoot it
Look for an O ring kit,,many times the firing cap seal splits thus loss of air
Mar 30, 2013 | Air Tools & Compressors
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
Dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Aug 19, 2012 | Dewalt Tools & Hardware - Others
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
When i push the trigger air is comming out but the gun is not shooting
make sure the safety release where the nail comes out is depressed. also check to see if it is low in nails/staples. I have an older nail gun that will stop when it is low on nails
Jan 13, 2010 | Grip Rite Grip - Rite 21 Round Head...
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
