Question about Aloha Housewares (93645) Ceiling Fan
Now that they no longer make incandesant bulbs i need a new globe to fit over the new bulbs
    Master:
  • 403 Answers
Where are you shopping for bulbs that your told incandesant bulbs are no longer. As a employee of the big orange home improvement center, I can assure you you can buy them there.
Posted on Mar 12, 2011
How to change fog light bulb
remove front glass screw remove light remove retainer clip fit new globe re fit back together.
Aug 28, 2014 | Crown Fog Light Bulb Jeep Grand Cherokee...
How to replace headlight bulb in 1987 toyota camra
For an 87 specifically, I don't know the answer, sorry. There were at least 3 designs used in the 93-94 models alone. If it is anything like them, you have to either
- press in the plastic barb clip on the centre of the wiring connector at the back of the globe housing, and pull down on the wiring connector to disconnect it. Then rotate the globe holder anticlockwise and withdraw it. Don't touch the new globe glass with your fingers, or if you have, clean it well with metho. Then installation is in reverse. Or for a different design,
- alternatively, unplug the electrical connector. Then turn the hard plastic cover, at the back of the headlight globe holder, anticlockwise and remove it. Then remove the rubber cover underneath. If you are replacing an outer bulb remove the bulb spring clip, first taking note of how it is fitted. On an inner globe there may be a covering socket over the globe itself. Remove that, and the spring clip underneath. Replace the globe. Installation is in reverse, making sure all bits are in position, and the 'lock' mark on the hard plastic cover is facing upwards.
Nov 16, 2011 | Toyota Camry Cars & Trucks
How many years do light bulbs live up too? And also how long can and do they last for then?
I don't know it depends on the light bulb brands and slso which type of a light bulb it is too.
CFL lights last longer than the traditional incadensent ones do. The incandesent one don't last as long because the way on how they were made back then old technology.
Aug 06, 2011 | Nintendo Wii Console
Replace headlight bulb 2006 Point
Under hood, remove large plastic wether cap from back of light, remove 3 point lug from unit, depress the rounded end of the retaining spring inside the open area,
while depressing it push it over to one side to release the pressure off the globe, remove globe, new globe will fit in only one position, be careful not to touch globes end with fingers as the oil in your skin is dtremental to its operation. assmbly is then in reverse. Good luck
Nov 20, 2009 | 2006 Pontiac Grand Prix
Changing downlight globes
if its the gu10 bulbs that you twist round to release them well theres a small ****** that sticks on the bulb and removes it leaving the actual light fitting in the ceiling.
Sep 27, 2009 | Electrical Supplies
Indicators running to fast. new relay fitted but didnt solve problem
Sounds like you have installed LED turn signals in place of the original incandescent ones.
You will need to install resistors in line with each LED turn signal to slow the flashing down back to normal.
"Trackside" products makes a load equalizing resistor for use with LED turn signals.
Sep 25, 2009 | 1976 kawasaki Z 750
Changing light bulbs in Hampton Bay 60 in. Miramar Fan
You have to unscrew the small openings on top of the housing where the motor is to access the small nightlight bulbs.
Jan 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
How do I change my headlight bulb
go to your parts suppler and ask for a H4 globe pop your bonnet and remove the plug on the back of your head light then remove the rubber boot paying attention to which way it cam off then you will find a spring clip unclip it but be careful not to damage its anchor point. remove old globe an throw away take new globe out of box DO NOT TOTCH THE GLASS OF THE GLOB AS IT WILL CAUSE THE GLOBE TO BLOW STAAIGHT AWAY AFTER FITTING IT handle the globe by the metle bass and fit it, refit spring clip and rubber boot fit the plugf and check the operation of the light
bingo you are done have a nice day
Dec 21, 2008 | 1999 Mitsubishi Mirage
CFL bulbs for fan fixture
I had a simple question and you wanted me to pay you to answer it.
I am still hoping to get a CFL lightbulb with socket size E17 to provide more light for my kitchen, but you won't help.
Screw you all.
Sherwin
Oct 06, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Sep 26, 2007 | Yamaha RX-V870 Receiver
Aloha Housewares (93645) Ceiling Fan Logo
29 people viewed this question
Top Aloha Housewares Dryers Experts
Mike Carew
Gene Haynes
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
