Question about KitchenAid KERC508LSS Electric Kitchen Range
Problem with the KitchenAid KERC508LSS Electric Kitchen Range front right burner only. How do I repair?
SOURCE: Kitchenaid glass top electric range
That error code is for the "open oven sensor". You probably just need a new sensor.
Posted on Jun 07, 2007
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
  • 718 Answers
SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
Posted on May 09, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
Best Regards,
Bruce
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
Replace cooktop
looking at the part breakdown for this unit, doesnt appear to be much a of a problem in replacing the top, teh gasket should come with the new top if not there is one available for purchase, but looks as if all you need to do is remove the frame(look as if 2 screws in either rear corner will release this)afeter that the glass should lift right up simply replace with new and re-secure the screws, be gentile however the new glass can be fragile, so make sure ut fully sits flat in the spot before trying to tighten back into place
Dec 15, 2008 | KitchenAid KERC508LSS Electric Kitchen...
Back burner not working properly
We have called a technician, who believes it may be the switch.
Nov 10, 2008 | KitchenAid KESC307 Electric Kitchen Range
My front burner not working.
Check to see that your simmer switch is in the off position, I just had the same problem and checked it back to the power connector and only had 120 V ????, I about to take the switch out and then saw the simmer switch that I never noticed. Clicked it to off and now my wife is happy again. Good Luck, hope your solution is just as easy.
Nov 07, 2008 | KitchenAid KERC500 Electric Kitchen Range
KERC600GWH1 glass control panel is cracked.
Replacing the Ceramic top is not difficult. Just remember to be careful. There should be 2-to-5 screws holding the top to the front support. Removing these screws will allow the top to be tilted up and back. Depending on the style you may have to remove the burner plates from the top. Remember to disconnect the power before attempting any repair
Oct 22, 2007 | KitchenAid KESC300 Electric Kitchen Range
Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | KitchenAid KERC507 Electric Kitchen Range
Open Questions:
KitchenAid KERC508LSS Electric Kitchen Range Logo
51 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
