Question about Kenmore Refrigerators
Describe your kenmore 363.78595896 Problem looking for dimesions of this unit
Need to replace transmission. How do I remove the necessary parts
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to give you an answer.
NOTE: If this is a basic top load, direct drive unit, and you can describe the exact problem, it's usually a lot less expensive (and relatively easy) to repair rather than replace a transmission.
Aug 14, 2010 | Washing Machines
Dell dimesion runnin win 7 only thing i
sir, i you have your motherboard installer you can use it to let you use your onboard video. please try to install it
Jan 21, 2010 | Dell Dimension 1100 PC Desktop
Describe your Kenmore Air Conditioner Proble. My
the vent is a fresh air intake, when it is pulled open you are mixing outdoor air in the unit. when it is hot and humid outside you will make the unit struggle to cool. Leave the vent closed.
Aug 22, 2009 | Kenmore 75085 Air Conditioner
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Hi, When the washer is set for cold water only, can you hear the inlet valve humming? Remove the fill hose from the inlet valve and look inside the valve to see if anything in plugging the screen. If the screen is open or the valve doesn't hum when there is power to it, the valve is most likely bad.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Sub box
it all depend on were you are putting these subs at. the dimesion on the trunk of a honda to a lincoln are vastly different
Jul 09, 2009 | Legacy (LA568) Car Audio Amplifier
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore dryer start switch needs to be replaced
Depending on age of unit.. there are 2 screws on each side of the console (older unit) on newer unit you have 2 white plastic covers.. pop those out and unscrew the 2 screws and lift up the console.. you have to get to the starter switch from the back of console.. good luck..
Jan 21, 2009 | Kenmore 63942 Dryer
Refrigerators Logo
118 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
