Question about Kenmore Ovens
F10 error message oven 790.9612 - Kenmore Ovens
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Posted on Mar 12, 2011
2 Suggested Answers
  • 89 Answers
SOURCE: Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
Posted on May 27, 2009
My Frigidaire oven shut off due to an f10 error which should I replace first since I have no tools to measure.ohms... sensor or EOC?
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
Feb 14, 2015 | Frigidaire Ovens
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 | Ovens
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
I am getting a F10 err message on my 790.9744/ 9745. I turned off the power and the beeping stopped and the clock flashed. Waited a while a turned oven back on and after 10 minutes it started beeping and...
Hi, the F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
Dec 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
What is F10 error code
http://www.applianceblog.com/mainforums/sears-kenmore/11065-kenmore-range-f10-error.html
Hi this website above directly addresses your issue.
F10, is an Over temperature, usually a bad thermistor or similar, as related see above post. For ID & repair parts and all.
Nov 01, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
Message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Apr 19, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
167 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
