Question about E-Machines 19" Widescreen Flat Panel TFT LCD HD Monitor
When i boot up the monitor says resolution reminder it doesnt match my tower set to 1280x720 than push auto button.how do i do that?the monitor came with computer from walmart it was giving to me.it works but looks drifferent.can u help me?the monitor says hd monitot emachines on it.
  • williekb2 Mar 12, 2011
    i did that but no change it says to push auto after i sit the resolution.
  • 68 Answers
SOURCE: setting resolution
Adjusting the resolution is done in Windows. Right click on the desktop and click on properties. Once that opens click on the Settings tab. There you will have a slider bar that you can adjust your resolution with. As far as being able to see things clearly on the monitor, the best picture is usually obtained simply by pushing the AUTO button.
Posted on Dec 05, 2008
leroyal
  • 2120 Answers
SOURCE: eMachine computer fans run but no monitor picture
Remove and reinstall memory.
Posted on Feb 13, 2009
michaelcanto
  • 76 Answers
SOURCE: My computer only displays the "eMachines" logo when turned on.
Hard drive failure
Posted on Jul 26, 2009
  • 17 Answers
SOURCE: Resolution issue with Emachines E211H flat panel monitor
Try to restart ur PC then it will auto detect ur monitor via DVI input. Actually, no driver needed for monitor in now day, they all come with plug and play.
Posted on Mar 22, 2010
budmrtn
  • 11361 Answers
SOURCE: My monitor is very blue and the words look
If you are getting blue cast on the whole screen, you should check the video cable pins and make sure they are properly seated, also try it with another PC to make sure it is not video card problem.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 30, 2010
Will a hp vp17 monitor work on a compaq presario?
All monitors will work on any pc/mac computer.
The only concern might be how old is the monitor (low resolution) connected to a brand new computer (high resolution). But it usually auto adjust at windows boot up.
Check the VGA connector (blue) or DVI connector (white) for the monitor matching the pc tower
Feb 24, 2015 | HP vp17 Monitor
Wrong resolution on smart tv- cvd601
I made the mistake of selecting the largest of the resolution settings of 1920x1080-50Hz. The CVD601 DOES NOT HAVE A RESET BUTTON! You have to do all your business on screen. So to regain my setting of 1280x720-60Hz, I disconnected from my TV and hooked up to my computer monitor. At that point, I got my picture back and went to settings. Upon restoring the settings in TV Screen Resolution to: 1280x720-60Hz just click and exit. In the US everything is based on the 60Hz cycle. Hence the hickup when you pick anything in the 50Hz cycle. I hope this helps!
Jan 08, 2014 | Craig Electronics Craig Smart TV HDMI...
Magicjack problems
Most of the time this is a case of the output resolution from your tablet does not match the resolution of your television.
Go to the Control Panel on your tablet and make sure the secondary video output is set to a resolution that the television can
display. Try 1280x720 and see if it displays. If this resolution does not work do a Google search on television resolution
settings and try the other standards.
Televisions for the most part compared to monitors can only display specific resolutions.
Dec 25, 2013 | Computers & Internet
Previous monitor 13 1/2" wide. I want to make
Check on the monitor for an auto button or function, this should reset the screen resolution to match the pc output, what resolution are you running at? 640x480 or 800x600 would be my choice for that size screen but try some of the higher resolutions in conjuction with the auto button to see if you can get the screen size you desire.
May 05, 2011 | Computers & Internet
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I have a resolution reminder window that pops up every time i turn on the monitor. i want it to stop.
hit the menu button on the side, then select to de-activate the resolution reminder.....also you can look up what is the best resolution for your screen, especially if you are playing video's and video games.......you can change the resolution in your control panal, then hit "auto adjust" and it should fix that
Jan 11, 2009 | E-Machines eMachines Monitor E15T4
Screen resolution reminder.
go to the control panel double click DISPLAY then select setting then select 1440x900
Jan 09, 2009 | E-Machines eMachines Desktop PC
I need a driver for gateway 17 in. wide screen monitor FPD1775W
You might want to consider a default settings reset. To refresh or reset the monitor back to default settings, unplug the monitor's power cord, and then press the the power button for five (5) seconds to drain any residual power. Plug in and then turn on the monitor. The default settings load.
Additional information about your monitor is available on the Gateway support website.
Nov 19, 2008 | Gateway FPD1775W Monitor
What is correct resolution for e17t4w
found correct setting on vista windows support, for emachines flat screen 17". the setting is 1280x720.
Aug 24, 2008 | E-Machines eMachines Monitor E15T4
Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
E-Machines 19" Widescreen Flat Panel TFT LCD HD Monitor Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
