Question about Kodak EasyShare C340 Digital Camera
YHE LENS WILL NOT OPEN /GREEN COMES ON THEN RED BLINKS
    Guru:
  • 441 Answers
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Apr 10, 2011
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
I am able to transfer images to my computer, but when I try to turn the M893 camera on when it's not connected to my laptop, the screen comes on for a second or two, lens comes out, green light is on and...
It has problem on the lens. Lens doesn't extend when transferring pictures that's why it works. Kodak cameras are designed to automatically shut-off when the lens is struggling to go in or out.
Follow step-by-step solution and repair on www.kodak.com/go/stepbystep if the guide did not resolve the issue proceed processing the camera for repair under the same website if it is still under in-warranty otherwise call Kodak @ 1800-235-6325 extn 1-12-2
1-English
12-Camera Dept.
2-Hardware and service dept.
Lester
Kodak Technical Support
Oct 04, 2009 | Kodak Easyshare M893 Digital Camera
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
My problem is exactly the same as the original poster's.
It may be that there is a setting in the camera that has been changed to make the camera only operate from the computer. I suggest looking around the menu in the camera when it is attached to your computer.
Aug 27, 2009 | Kodak Easyshare M893 Digital Camera
Will not show screen
pls try some solutions below
check batteries are they fully charged and supply good power, try replacing them .
check the memory card is it formatted properly try to re format on Laptop card reader, and also check mem card compartment is it closed properly
do u see anything on LCD if not then problem can be big as CCD Failure
does the lens moves and comes out do u hear something
pls check and tell me if u find me helpful
Dec 29, 2008 | Kodak EasyShare CX4230 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
