Question about GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator
HOW TO TURN ON ICE MAKER TO GE GSL25JFXNLB - GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator
  • 827 Answers
There is no on-off that I've ever seen... however if the filter is plugged or water flow to the make is diminished or otherwise blocked, it will not work..
Best regards
Ck
Posted on Mar 12, 2011
I have a GE refrigerator model gfss6kkycss with a Samsung ice maker model DA97-07365A the problem is it is not making any ice and the water dispenser is working fine
-Make sure turn the ice maker " ON"
If it's on then the Water valve to the ice maker might not function.
Good luck
Mai
Oct 26, 2017 | GE Refrigerators
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    MY GE MONOGRAM ZIS420D FREZZER IS NOT MAING ANY ICE. WHAT SHOULD I DO
    check for continuity on the ice maker water fill solenoid valve in the lower rear area of the refrigerator,then remove cover from front of ice maker, and there are 2 gears inside this cover,follow the instructions on the ice maker by this gear and turn it the way it tells you to,this will initiate a manual ice production,you will see the gears turn by themselves after you help turn these gears initially,then you should see water enter from fill tube in the back of the ice maker if the fill tube isnt froze over,if no ice production occurs the ice maker thermostat could be open(bad) or if it makes ice but doesn't push it out the heater below the maker may be open(bad)
    Aug 12, 2012 | GE Monogram ZISS480DRSS Stainless Steel
    Installed new valve, getting water to valve but ice maker will not cycle or call for water
    GE's ice makers are harvestable, means you can manually tell the ice maker to harvest or cycle. Turn ice maker off, went 5 seconds, turn ice maker back on, tap the paddle 3 times (push the paddle inward completely) then it should cycle, may have a delay like 20 second. I hope this helps.
    Jul 12, 2011 | GE WR57X10033 GE Refrigerator Water Valve
    Ice maker is not working
    Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    Mar 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
    Ice maker in our GE profile refrigerator is not working
    Ice maker Diagnostic Test:
    - Remove the ice bucket
    -Turn the ice maker off, wait 15 seconds than turn it back on
    -Press the ice paddle three times, this will begin diagnostic test.
    -PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
    -In 3 minutes you should see the rack inside turn 360 degrees
    -AND the ice maker bowl should fill with water
    -IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
    Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Ice maker stoped working
    Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
    GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator Logo
    235 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Ilia Bichin
