Question about Car Audio & Video
Hello, ive got a Eonon g1301 dvd head unit, and have a problem with the screen. When i turn it on the screen is meant to slide out then flip up.This has been fine up till now and have had no problems. Turned it on today and the screen only slides out and does'nt flip up, ive tryed pressing the reset button but still have the problem. Any advice would be much appreciated as ive got a car show to go to next week where ill be doing some sound competitions and need the screen to adjust things. many thanks devil racer.
  • 556 Answers
SOURCE: Sanyo Tv color problem
Hello, The TV is four years old. About two weeks ago the screen suddenly had a complete red tint. I tried adjusting the color settings but nothing really improved. the next time I turned it on, it was fine. But the time after that it turned red again. Now it more and more often has a deep red tint. Any advice? Thanks please do not adjust any thing. your problem is in red color cathode ckt it might be loose contact in red cathode. crt base might be loose. check red output supply. signal line from chroma ic to crt base. regards thanks
Posted on Sep 11, 2007
SOURCE: GPS Won't Turn On
My 510 was doing the exact same thing.
I called customer support and they helped me get it working again.
866-486-6866 is the number but here is what they had me do.
I had to push down the reset button for 15 seconds (the reset is in a small cut out near where you plug in the charger on the bottom.you will need to use a pin and you will feel the pin push in the button if you have it in the right spot.)
Then release the reset and hold down the power button for 10-15 seconds. the screen should come right back on.
If you need more help I suggest calling the 866# they are very helpful.
Posted on Mar 13, 2008
SOURCE: kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Posted on Mar 26, 2008
  • 236 Answers
SOURCE: Tray opens but won't close or closes but doesnt play
deferctive laser lense already. try to replace if more economical than buying new unit
Posted on Mar 31, 2008
SOURCE: iPhone slider won't slide all the way across
I'm having the same issue, have you found any solution?
Posted on May 19, 2010
Eonon d2208 cd player form my car i want to know how to install it into a 1999 toyota pardo
when i go to watch my dvd in my car with my eonon d2208 it comes up with a safe mode so i can hear it but no screen picture how do turn it off
Aug 12, 2010 | Car Audio & Video
Hi ive got an eonon e1012 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i put in a cd...
hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
I think maybe you have connect the wrong wire and have bum out the built in amp.
Nov 08, 2009 | XO Vision XO9013 Car DVD Player
Can I install the eonon 1091 in an 1999 acura RL?
Hello anthony_owen,
No, it won't fit.
The Eonon E1091 is a "double din" unit that requires at least a 4" tall opening to slide into. Your Acura has a "Euro-din" opening that is only 2" tall.
Hope this helps.
Oct 14, 2009 | Car Audio & Video
Eonon 4inc incar dvd player lights come on but screen stay blank
check to see if the brake wire on the head unit is pos or neg once you find that out go to auto zone and buy a toggle switch and run the pos or neg to one end and the brake wire from the head unit to the other and the sequence is 2 seconds on to off reffer to your manual to be for sure
Mar 02, 2009 | Car Audio & Video
Screen pic looks like negative
well, in this situation, you can go to the EONON customer service, try to figure out, and they have a 2 year guarantee.
Jan 03, 2009 | Audiovox VOD102 Car DVD Player
I have an eonon GPS/DVD/Bluetooth flip up touchscreen car stereo. Navigation works fine; when I swith to dvd or backup camera, unit screen shuts off.
Do you have the PARKING BRAKE ON??? You need to have the wire coming from the back labeled PARKING BRAKE hooked to ground. You also might have a radio damaged during installation. You can email me at eightballproaudio@yahoo.com, I am an unauthorized distributer of eonon radios...
Dec 12, 2008 | Car Audio & Video
Eonon faults
You have only conected the live feed, that will cause the light to come on but not switch on. You must conect the switched live feed as well, then it will turn on.
Good luck
Aug 07, 2008 | Car Audio & Video
Eonon "warning"
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 18, 2008 | Sony MV-900SDS Car DVD Player
Eonon gps e0855
The brown wire, safety ground? needs to connected the ground (-ve), or the vechiles chassis, this a saftety circuit so it wont work unless this wire is wired to the negative of the battery.
Jun 03, 2008 | Car Audio & Video
Jensen model#vm9411
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the blue one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Feb 25, 2008 | Jensen VM9411 Car Video Player
Car Audio & Video Logo
122 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
