Ide cd - Computers & Internet
    Brigadier General:
  • 8,909 Answers
Please clarify if you have a question
Posted on Mar 12, 2011
What is the position of the link do I need to change to master/ slave etc
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Need diagram info for master and slave driver
hope this helps
Dec 06, 2010 | Samsung TS-H492 (TSH492AWRBH)...
SUPER X5DPA-GG mainboard doesn't find connected ide hard drive. All bios and mainboard drivers are current. Board finds cd-rom in ide 1 and 2 but wont read any hard drives. IS THE MAINBOARD FRIED. IDE...
Never put the CD on IDE 1
The IDE hard drive should always be alone on the first IDE channel.
CD-ROM drives can slow down the transfer rates and cause other screwups, and so they should always be on IDE2 or as high as possible (Add in Cards)
Sep 05, 2010 | SuperMicro X5DPA-GG (672042882748)...
Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | E-Machines eMachines Desktop PC
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
My cd-rom has trouble reading disks
1.some times this happened the loose connection of the IDE cable,and power cable.
2.so disconnect the IDE and power cables and then connect again.
if not fix
3. exchange the IDE cable of hard disc.
4.if no result,the lens of CD Rom has damaged, you will be have to buy a new CD rom....
thanks!
Mar 02, 2008 | Computers & Internet
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
