Question about GE ZSC2001FSS Advantium Electric Single Oven
Advantium ZSC2001FSS 02 oven with F3 error code ( touch display shorted out) 3 years old. Apparently a wide spread issue. Is this worth repairing or should it be replaced with a better designed unit?
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: F3 Error
This is due to a Defective control board..You have to get it replaced..
Posted on Oct 22, 2007
SOURCE: advantium zsc2001fss no power no lights
I have same unit...power outage made unit come back on and it then requested user to set the clock, but the display shows the hours but won't accept the pushputton to lock it in. I had to look at the control panel today to see how hard it would be to replace.
To take off the front vent panel: first take microwave out of the built-in space, disconnecting the power cord. Then the top outer metal skin can be unscrewed and removed, which exposes the screws that hold in the front top vent and the control panel in place.
Posted on Aug 08, 2008
localwonder
  • 6784 Answers
SOURCE: Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Jul 18, 2009
  • 272 Answers
SOURCE: I have a GE JTP27 double oven, now 12+ years old.
Greetings,
its possible to be the oven sensor or something in the lock circuit...if all else fails then in the electronic oven control which costs 125.00 or there about...might find cheaper price on ebay or internet search The sensor about 40-60 dollars, but without a complete number its hard to be exact with a price or part list...if this is helpful ..please let us know or if I can be of more assistence. let me know...Bruce Denton
Posted on Dec 28, 2010
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
Error code f 03 has come up on our oven
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Nov 05, 2007 | Blodgett DFG-100 Gas Single Oven
The GE Profile Advantium SCB2001KSS started beeping and displaying error code F3. I was able to set the time after holding one of the controls in for 3 seconds, but it reverted to the beeping and F3 error...
Oct 19, 2007 | GE Profile Advantium SCB2001KSS Stainless...
F3 Error
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
F3 Error Code
Oct 12, 2007 | Ovens
Unit has no power.
Aug 22, 2007 | GE ZSC2001FSS Advantium Electric Single...
Door is loose
Oct 16, 2006 | GE ZSC2001FSS Advantium Electric Single...
GE ZSC2001FSS Advantium Electric Single Oven Logo
104 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
