Need help accessing my netgear mr314 wireless router with the default username and password after i have reset it
  • 4,281 Answers
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Mar 12, 2011
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings.
Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
Nov 05, 2013 | Computers & Internet
How do I reset my password?
Step 1:
Wireless networking is a common feature in homes and offices. Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network. If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu. Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings. Disable the wireless security. Reset to Factory Defaults Locate the reset button on your router. Typically the reset button is a small indented hole on the back of the device. Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings and add security as necessary.
Feb 27, 2013 | Computers & Internet
Need password for wireless roter
If you need the login password for the router's setup page, the default username: admin, password: password.
If you need the wireless key or password, you need to access the router's setup page by typinghttp://www.routerlogin.net or 192.168.1.1 in the address field of your browser(IE or Chrome). On the login use the default username and password(admin, password).
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the WEP or you can setup wireless security from there if you haven't done so.
**If by chance you are unable to access the router's login or setup page, you will have to reset the router to factory settings by holding the reset button on the back of the router using a paper clip or a pen for 30 seconds while the router is plugged in to the power outlet. You will then be able to access the router's setup page using the default username and password.
Hope this helps.
Oct 16, 2011 | NetGear WNR2000 Wireless Router
Lost my password
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password.Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router Reset for most routers with a reset button on the rear panelWrite down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Sep 20, 2011 | NetGear WGR614 Wireless Router
I need my netgear password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Reset and Restore the NETGEAR device to Factory Default Settings
Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Click here for video walk through example of how to reset the WGR614v9 router.
Resolution:
Here is a small video that shows you how:
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Good luck.
Mar 10, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Need to find out password or how to reset a new password
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Can't access 192.168.1.1
  • Username = admin
Or you will need to update the firmware to rest the router.
Nov 08, 2009 | NetGear RP614 Router
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
Apr 06, 2009 | NetGear WGR614 Wireless Router
Default pasword
The initial factory default Web Manager password is '1234' and the user name is ?admin?. Doc ID: N100515.asp
Feb 19, 2006 | NetGear MR314 802.11b
Computers & Internet Logo
David Payne
David Payne
