Question about Refrigerators
I have a breez aire wkce 1060 r134a.. what should the low side pressure be at/
    Sergeant:
    Champion:
  • 247 Answers
The low side pressure is defend on the size of your ref.but if it is use in home appliance not in commercial it its range 12 psi more or less but yuo consider the cooling temp. of your suction line but if it look sweating it means your suction pressure is ok if not add refrigerant charge until it sweat.
Posted on Mar 12, 2011
Replaced all A/C major components (compressor, filter-drier accumulator, and orifice tube) except condenser due to a seized compressor and failed clutch bearing. Flushed system and appeared to have no...
It sounds like you've done just about everything except to check if there is a bad or intermittent wire causing this or perhaps your low-pressure safety cutout switch is possible going bad causing the compressor to kick on and off?
Nov 01, 2013 | Lincoln Town Car Cars & Trucks
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
2006 Ford Fusion Air Conditioning compressure not turning on.
Thats pretty high if the system is not running. Average pressure on the low and high side should be near outside air temp.
Normal low side is 30-40 psi and high side is 200-250 psi when the system is running and the freon charge is full.
Aug 28, 2012 | 2006 Ford Fusion
How many ounces of r22 does a WKCE 1060 hold at full charge?
A WKCE UNIT SHOULD BE AN R-134A SYSTEM NOT AN R-22 IF IT IS A R-22 IT SHOULD SAY SO ON THE TAG ON THE BACK OF THE UNIT NEXT TO THE CONDENSER COIL(BEHIND THE WHITE GRILL) IF IT IS AN R-22 IT SHOULD BE A MECHANICAL THERMOSTAT UNIT (SCREW ADJUSTMENT ABOVE THE FRONT BROWN GRILL)
IF R-22 MODEL 2200 13 OZ
IF R-134A MODEL 2200 10 OZ
MANUFACTURER CAN PROVIDE INFO ALLSO AS LONG AS YOU PROVIDE THEM WITH MODEL AND SERIAL NUMBER OF THE UNIT 858-566-7473
Aug 27, 2011 | Breezaire WKCE 2200 Wine Cooler
What refrigerant is use for BreeZaire wkr 1060 and
A WKR 1060 SHOULD BE AN R-22 REFRIGERANT UNIT AND IT SHOULD STATE SO ON THE UNITS TAG ON BACK OF THE UNIT.
I IT IS IN FACT AN R-22 MODEL 1060 IT USES 9oz OF R-22
IF IT IS AN R-134A IT USES 10 oz
Dec 02, 2010 | Breezaire WKCE 2200 Wine Cooler
The air is blowing out hot. how fo i fix
If the a/c compressor clutch is not engaging, then the freon or r134a pressure may be low.
Pressure on the low side should be 25 psi to 45 psi.
Since your car is a 1990, it may have been made before r134a was used and may require an r134a retrofit kit that includes oil, r134a, and adapters to update the a/c.
R12 used to be used but is very expensive and requires a certified techncian and recovery and recycling equipment to use, and probably would leak out faster than the r134a system.
Aug 10, 2010 | 1990 Chevrolet Corvette
Low side on ranger for the port on the ac
hmm ..if you are looking for the low side air conditioner port .. then locate the condenser (thats in front of and looks like the radiator) .. you will notice two tubes going to that ..one is large the other small .. the small tube is the high pressure side .. the large tube is the low pressure side ... follow the large tube back until you find a cap that covers the low pressure port .. thats where you would fill with new refregerant (r134a) .. if you buy r134a, you can also get a filler hose and gage.. that hose will only hook up to the low pressure port ..it wont fit the high pressure port ...
Jul 03, 2010 | 1994 Ford Ranger Supercab
Air is not very cold on a rv roof top ac what tools are needed in recharge
You should have the manual for this unit handy and as far as recharging tools go. You only need a can of R134a *(if the unit is R12 you need to buy upgrade adapters since R12 is no longer sold) Run the unit and put the R134a filler line on the low pressure side of the compressor *(from manual...dont guess as trying to charge the high pressure side is VERY dangerous). Get the charge just into the Green zone on your charger and that is it! Try not to fill too high in the green zone....I know it sounds funny...but AC's usually work better when they have the low end of their optimum fill. R134a doesnt work as well as R12 so be sure you buy the R134a with cooling enhancers. Your local Autozone can guide you to the right filler/product combination.
Good luck and be careful!
Jun 30, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioning compressor will not come on.
either the low pressure switch in the low pressure side is bad you can bypass it to check it,or its low on r134a refrigerant and thats the reason the low pressure switch wont close or the 12 volt fuse and relay arn't getting power
Mar 31, 2010 | Heating & Cooling
Can of r134a hose won't stay on low pressure port
Low side is the smaller of the two fitting wise, but usually the bigger hose.
Jun 25, 2009 | 1997 Buick LeSabre
Refrigerators Logo
170 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
