Question about Keurig B60 Coffee Maker
Piece that holds the sharp point that pierces the cup is broken I want to get the part so I can replace it. I have taken it apart.
  • 57 Answers
All parts and service related issues go directly to Keurig. There are no secondary or contracted parts makers for them. Here's the munber to call them
1-866-901-2739
Posted on Mar 12, 2011
  • 10,865 Answers
Hello dmur.... go to this keurig link to order the part you need
http://www.keurig.com/customer-service/brewer-registration-and-support/maintenance-and-cleaning
Joe
Thanks for choosing Fixya!
Coming out in short spurt will not coffee cut up
there are a few things that can cause this;
1) You may need to clean the needle in the coffee exit where the coffee pod sits and gets pierced when the top is closed. You do this with a needle, be careful the point of the piercing nozzle is sharp and the needle point is as well.
2) There is also a needle in the cup holder under the pod that cuts the hole for the coffee stream, this needs to be cleaned with the needle.
3) The filter in the water tank may be plugged and needs to be cleaned.
4) The pump may be clogged with lime and scale.
5) The heater element may be scaled with lime.
6) Items #3 to 5), to fix this use DE-scalier, or vinegar solution, the pickling strength works better than household variety, but both are OK.
7) run the cycle for coffee, no pod, 3 times, this should clear the taste of the vinegar.
Hope this is your solution.
Mar 17, 2015 | Keurig B70 Coffee Maker
Why does the water splash around the cup rather than stream out ?
Check the removable insert that pierces the K-Cups. It may be dirty from coffee residue and needs to be cleaned. The entire assembly turns and lifts out but be careful as the piercing needle is SHARP. After cleaning, try a new k cup and see if it works ok.
Sep 12, 2014 | Manufacturer KEURIG Brewer a: Mr. Coffee...
Replacing keyboard Dell Inspiron 1405
get a sharp instrument like a knife or a flat head screw driver and look at the rim of the keyboard and theres pushed in gaps put the sharp instrument in there and turn it towards you and it should lift out.
best regards
Jul 11, 2010 | Dell Computers & Internet
The water will not go through the pod to make the coffee. If you remove the pod then the water flows. If you want tea the water goes through with no problem. We tried the vinegar but that didn't work...
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
May 17, 2010 | Keurig Elite B40 Coffee Maker
Part that holds the coffee cups that pierces both top and bottom
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
May 14, 2010 | Keurig B50 Coffee Maker
I broke the green plastic piece off that holds the ink in my sharp ux b700 fax machine where do i get a replacement
Take your ink out of the fax and clean the broken part with alcohol and then just super glue the piece in, it does not have to hold any weight, so you shouldn't have any problem with it if it just holds the ink. Super Glue and plastic work great together.
Mar 19, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Broken cup holder in 2000 BMW 740iL
unfortuantly the whol center councle needs taken apart it is harder than it looks sorry for the bad news, an easy fix is to just replace the front part of the cup holder
Mar 24, 2009 | 2000 BMW Z8
Replacing the foot pedal
there is two C clips on the pin that must be removed first. then the pin will come out. if you need a picture of this or have any other trouble feel free to let me know. I also stock those foot pedals if you need one.
Aug 10, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
My fridgidaire ultra quiet 3 dishwasher leaks...
a common place to leak on these machines is through the heater leads. run the machine w/lower panel off and see where its coming from , if its dripping down the heater leads, chances are the 2 nuts that secure them are broken and need replacing
Mar 04, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Keurig B60 Coffee Maker Logo
121 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
