My York 1hp split unit air-con power light blinks twice stops and repeating, I know its a warning sign that something is wrong. I would like to know what is it trying to tell?
  • 86 Answers
SOURCE: Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
Posted on Mar 15, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 124 Answers
SOURCE: York Air Handler trips main circuit breaker
almost has to be the electric heat strip coils. they usually come on in stages. when the damaged strip comes on it kicks breaker. turn off all power, check with a meter , gently remove strips and inspect for broken or shorted coils. usually best to buy a new heat strip module. they are usually held in place as a module with 4 screws and a snap together wire connector .good luck. i have had some success if the wires are broken and not to brittle by bending a minute loop in the end of each wire and reconnect with the tiniest screw and washer and nut you can find, i'm talking real tiny. about the size of a bb if you can find em , or you can remove the damaged strip wire entirely to get some heat from remaining.
Posted on Nov 23, 2008
notsomot
  • 67 Answers
SOURCE: my split air con unit is leaking water from the unit in house
The things that you can check yourself are
is the indoor unit level?
Are the filters clean?
The area the water is draining to free of obstruction?
Is the drain actually draining?
----Get a cup of water and pour it over the indoor coil (please make sure the power is off first please) If the water does drain then it is prolly a bigger problem.
Prolly your unit is short of gas and need a refrigeration tech out to check. That it isnt ice-ing up but you would notice the performance drop.
Hope this helps
Posted on Jan 08, 2009
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
Blinking power light
Make sure voltage and polarity is good
Dec 17, 2013 | LG Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
My portable air conditioner stops blowing cool air after a while and the light is flashing with a sign "lo" Does anyone know what this means?
Flashing lights are generally a sign of something wrong or something needs attention. Try emptying the water canister, cleaning the filters etc.. Not sure what LO means on your model. LO on some wall mounted splits means that the room temperature is below what the remote control can pick up.
Jul 03, 2011 | Heating & Cooling
My M30CF AC unit is blinking green and red twice and then red by itself 3 times. then repeats. My air conditioner is shutting off randomly and doing this. Can you tell me what the problem is?
If you have the manual for your unit... look in the troubleshooting section and see what that combination of lights means... those lights are flashing a code at you telling you what is wrong...
When you get the explanation, then comment back and tell me... I may be able to help correct what is going on then....
BTW, did you try to recycle the power to see if it goes away???
heatman101
Nov 15, 2010 | Friedrich M30CF Split System Air...
May 08, 2010 | Samsung AS18A6RB Air Conditioner
How to trouble shoot my split air cond at home
The 1hp split unit, How to solve the timer ligth blinking.
Rgs
Feb 23, 2010 | Heating & Cooling
York mini split unit has power but will not come on stand-by.
york split ac indor unit no working .timer light is on . how to stope timer control light ?
Jan 12, 2009 | Frigidaire FAA065M7A Air Conditioner
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Feb 14, 2008 | Heating & Cooling
Heating & Cooling Logo
281 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
