Question about Norelco 7737X Electric Shaver
Batterys loose charge quickly - Norelco 7737X Electric Shaver
  • Norelco Master
  • 1,612 Answers
Your battery pack is worn out. You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Mar 13, 2011
The cell looses battery too quickly?
The battery may be reaching its "end of life" and is unable to take a full charge. This can happen due to frequent charging, charging before fully discharged, age, or incorrect charger etc.
You should consider purchasing a new replacement and making sure you're using the proper charger with the phone OFF.
Mar 13, 2015 | Samsung GALAXY ACE II X Ace2x S7560...
My battery looses it's charge quickly on my x5 bmw 4.4
Find good Auto/Electrical Shop and have checked for battery drain
Mar 15, 2014 | BMW Cars & Trucks
Ingnition disabled
Battery may be low on charge, or a loose or poor connection between battery to starter, or battery to ground. Check connections, check cables, see if battery needs a charge.
Dec 02, 2013 | Buick Terraza Cars & Trucks
My samsung L730 digital camera will not turn on, i have charged it overnight and am using a lithium ion rechargablt battery that came with the camera
Some lithium-ion really loose their life easily and sometimes quickly.They are affected by temperatures too.I noticed that when I am charging the batteries tend to heat up and I found out they loose their power quickly when you let them charge and leave them warm.Secret to of prolonging their life is after a full charge zip lock it and freeze them.Of course dry them upon use.Do try a new set of batteries it will resurrect your camera back to life.
Nov 25, 2010 | Samsung L73 Digital Camera
Why wont my zune stay charged?
If your Zune is loosing charge quickly, its probably a battery issue. If you use your Zune often and for a long period of time, and end up charging it all the time, then your battery is becoming faulty because over time batteries loose charge. Or if its not charging, your Zune USB cable could have loose wiring. Zune 120GB owner.
Feb 14, 2010 | Microsoft Zune JS8-00001 Digital Media...
O2 orbit losing charge very quickly
my xda orbit is loosing charge quickly too, if i find a soloution ill wb.
im going to try a thorough clean of the motherboard, scratch connections etc and a hard reset.
looking like a new battery may be in order though..
think there £5 on ebay..
Dec 26, 2009 | O2 Xda Orbit Smartphone
I have a sony dcr-dvd108. the battery is fully
it might be battery to used and it's charging quick and loosing power to quick. have tried to change battery for new
Aug 24, 2009 | Sony Handycam DCR-SR300 Camcorder
Problem charging my laptop. I have to wiggle and trick it to charge it.
Seems that either the power socket in the laptop has a loose connection, or the battery terminals are not having good contact with the metal prongs connecting it to the laptop charging circuitry.
A quick check to see if the power socket has a loose connection is to remove the battery & power the laptop only from the adapter. If the laptop works from the adapter without having to be wiggled, then the problem is not with the power socket. Instead, it is the battery contacts. Try to clean the contacts using a non-oily contact cleaner & see if this resolves the problem.
Jul 19, 2009 | HP Computers & Internet
H700 Loosing Charge Quickly
I think the normal talk time is around 6 to 8 hrs if your battery is holding less you probably have a unit with a faulty battery
how old is your headset
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
Norelco 7737X Electric Shaver Logo
88 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
