Question about ASUS Eee PC 1000HE Netbook
When not on battery power, my time and date are incorrect and the startup screen is black BIOS requesting me to adjust the time. after i do, and hit F10 key, windows opens normally. I think the CMOS battery needs replaced. Where is it located in my netbook???
2 Suggested Answers
  • 6771 Answers
SOURCE: my time and date are incorrect and the startup
By your description you need to replace the c-mos battery on the motherboard, it provides the power to the bios chip so the date and time are not lost. I recommend a technician because the unit must be dis-assembled to access the battery for replacement. This problem occurs every time you start up the computer, making you correct the time and date every time it is turned on.
Posted on Mar 13, 2011
Time and date are not set correctly
When the Date and Time is set in the BIOS setup or in Windows and when you boot up next time and the date and time are incorrect then the problem is a flat BIOS battery. A flat BIOS battery cannot keep the Data and Time stored in the BIOS. Replace the BIOS battery and set the Date and Time etc and the problem will be fixed.
Apr 04, 2012 | Toshiba Tecra S3 Notebook
My time and date are incorrect and the startup screen is black BIOS requesting me to adjust the time.
If you are using Windows XP/Windows 7 all you have to do is right click on the time in the taskbar, and click properties. Click on "synchronize with web" (or something to that effect) and it will sync to an online server, thereby fixing the problem. I don't know exactly how to do it, since I am not running Windows, but I've done this before on my mom's computer. :)
Mar 13, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I can't get into the Bios of me ASUS A7V8X Motherboard. I hit del and nothing happens. until i stop hitting del, then it just starts windows xp up normally. Every now and then it enters the bios on it's...
Probably the battery. Easiest way to check is first disconnect from internet, then check date in xp, if says year 2000, your bios has been reset to default, probably from dead battery. Check by unplugging computer and pressing power button 2 or 3 times, then remove button battery and move pins to clear cmos, after 10 seconds, replacd pins and reinstall battery. Bios should then boot to default settings. In General tab, set correct date. If xp still shows incorrect date, you have a dead battery.
Nov 23, 2010 | ASUS A7V8X Motherboard
My pc automatically get start on plug on .and then it suggest me to press F1 to Continue. when I do this it takes incorrect date and time how to restrict it.I want to start it with start button on cabinet
There can be many reasons...
  • Your BIOS setting is not correct.
  • CMOS battery is down(Most probably).
  • both
You can open the BIOS setting page by pressing keys like DEL, F10, etc. depending on your system's manufacturer at computer startup(post screen). There are lots of wakeup options check them properly.
One of the option is "Restore last state of power Button on failure" which can turn on your computer without touching the power button. you should check these options.
And it suggest you to press F1 because your system's date/time is not configured properly. You can also set Time/date in BIOS also.
If your BIOS Battery(CMOS) is not weak or dead then after setting these values your computer should start properly.
And if your BIOS battery is dead then all the settings will be lost(date/time etc) after a restart and you will face same problem again...
Try changing the Power-button option and Date/Time in BIOS and see if problem persist....if yes then you have to change COMS battery that is on your Motherboard.
Sep 22, 2010 | Computers & Internet
How can i unlock poweron password for toshiba A300?
As you describe your problem I can see that your laptop ask for password just in the begining, in black screen so you need a bios password. That's diferent from the password that sometimes windows ask to (usually user - password).
Well you have to open the case of the laptop and locate a small circle battery, this is the bios battery. Eject this battery and the laptop's battery and unplug the power cord. Try 2-3 times to power up the laptop (without batteries or power supply, just for the capasitors to discharge). Wait 5 minutes. After that plug in again the bios battery, the main battery and the power supply. Start up your laptop. Just before Windows logo comes up hit del (or F2) repeatly in order to get in to bios settings. Find the command "load bios default" and hit enter. Adjust the date and time and any other settings you wish (boot order e.t.c.). Save the changes and reboot. As you can see you are ready.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 17, 2010 | Toshiba Computers & Internet
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Acer Aspire T690 will not post. When powered on no video
You need to remove The Side-Panel. ( Power Lead out )
locate A small round Button Cell Battery.
As big as a 1p or a Cent Piece. ( Usually silver )
carefully prise the Battery Out For Between 10-15 Seconds, And Replace it. replace the power cable. switch on the computer, the bios has now been reset to it,s factory default settings.
if you are prompted to set date/time enter bios ( F2-del Or esc ) dependant On Bios request.
This Should cure your Problems.
Mike @ Compurepair.
Oct 16, 2009 | Acer Computers & Internet
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
PRESARIO 700 ERROR ON BOOT Hello! Every time when I switch on my presario 700, on the screen show: ERROR PCI on motherboard, device 09, F1(boot) and F10 (setup). OS is XP pro. What is wrong?
If you know how to set up the bios hit f1, if not hit f10, it will boot up and you will need to reset the time and date as they will be wrong. The PCI error refers to a PCI slot, which for some reason isn't functioning properlly. If you run the disk with your motherboard settings that may have come with your motherboard it may just be a driver. If you hit f1 then you will be in the Bios screen. There the keyboard is used to navigate. The mouse won't work, Arrow keys for up down and side to side, and the escape key to get out of a menu or menu item, and enter to select an item. So on the first screen, you will need to adjust the date, time, and year. each time you do this you must hit enter to proceed to the next item. once you get all of the settings right hit f 10, and enter to reboot. So I gave you both ways. If you still have the problem, check the cards that are in your motherboard, there may be a loose one, also try to pop out the battery inside the case, not the laptop battery, if it continues to happen, you may have to pop that little battery that controls the settings for startup, it will reset your saved motherboard startup settings, and once in a while the battery may be bad, which can also cause the kind of problem you describe.
Apr 20, 2009 | Compaq Presario 700 470024-192 Notebook
Toshiba Satellite M45-S169 won't boot
you must restore your bios settings to the correct ones. contact toshiba customer support for the correct toshiba settings.
Jul 27, 2008 | Toshiba Satellite M45-S169 Notebook
ASUS Eee PC 1000HE Netbook Logo
181 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
