I have a GE "spacesaver"
  • 26 Answers
I would take a close look at the switch & take note of the following.
How does it attaches to the PC board?
How do the wires attach?
What is the physical size?
Then go to www.mouser.com or www.digikey.com and start switch shopping. If you look at the catalog view for the style of switch you looking for it is easier to find a replacement my visual cues, instead of part numbers.
Worse case scenario if it is simply switching the 2 attached wires, a different micro switch could be used & glued onto the existing board where the old switch has been removed.
Or.... you could simply short the 2 wires together to bypass the purpose of the switch, but the unit would always be on.
Posted on Mar 16, 2011
"door error", "start?" - When
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It doesn't heat anything. Could putting metal in microwave result in this problem? ge spacesaver microwave.
This is usually caused by a "Blown" magnetron, and or the High power Diode And YES, putting metal inside the MW, will cause it to fail.
You need to get a "Quote" for any repair, as the repair may cost nearly as much, as new unit. Also the new unit will have a warranty.
Jul 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need schmetic for ge spacesaver model jvm1653wh01 need to replace upper door switch
remove micro switch and can be purchased locally electronics surplus or Radio Shack
Mar 13, 2010 | GE Microwave Ovens
GE Spacesaver microwave always runs when the door is shut
I see this all the time. In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 10, 2010 | General Electric Microwave Oven
I want to replace a 1986 GE spacesaver microwave and replace it with a new microwave. The GE Spacesaver oven does not come away from the wall. All 4 bolts into the top of the oven are removed. It is no...
There are three things that can hold it up still.
1. Is there is an 1 inch tall duct piece that holds all the ducting to the microwave on top. look for screws going down to hold in place. Right and left side.
2. If you remove the top grill you will see to screws on the left and right side that go to the back of the microwave they hold to the back wall plate. about 1 inch down and 1.5 inch in from side.
3. Plug wire can hold it in place also but not likely. Just need to pull top down first.
If you have model number I will try to help more sense all are different on mounting.
Dec 21, 2009 | Kitchen Ranges
GE Spacesaver XL
fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – karlet@bellsouth.net
Jun 20, 2009 | GE JVM1339BW/WW Microwave Oven
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Apr 05, 2009 | GE Microwave Ovens
Theres a load stuck in my washing machine. the washer will not start. it keeps saying "dL" and "f". the owners manual does not say anything about "dL" what do i do?
Hi xstar57x
This suggest problems with the door lock/unlock mechanism
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Note: The door lock/switch assembly can be manually unlocked.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Regards
Nov 16, 2008 | Whirlpool Washing Machines
GE spacesaver 05GP009
I had this same problem, I wanted to use this tv with a converter box and the only way to do this was to hook up the converter box with an external antenna to the small 3.5mm input on the back. If you go to radio Shack and get an "F to 1/8" Adapter"the radio shack part number is "278-257". It worked perfectly. I'm able to get many clear channels, and with the converter box I now have remote control. It works well. Good luck, I hope this helps
Mar 02, 2008 | GE SpaceMaker 05GP009 Television
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
 Grubhead
Grubhead
