Question about LG WM2301HW Front Load Washer
My lg squeals badly when it is filling up? any solutions
  • 827 Answers
Depending upon how much the washer has been used (if not excessive enough to wear out the pump), then you may have a simple case of a pinched water feed line, the water feed may have been turned off? there may be a filter on the feed which is plugged and finally you should already know the quality of your water, and if there is (calcium or other hard water?) build up enough to plug the feed line that may be the culprit -- check & fully inspect the condition of the interior of the feed line..
Best regards
Ck
Posted on Mar 12, 2011
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Squealing sound when making ice
most of the time it is the water pump is going bad. It squeals real loud.
Sep 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Lg WM2701hv hose squeals while filling
The only solution would be to replace the water valve. You will need a qualified technician to help you.
Good luck
Jun 10, 2011 | LG WM-2277HW Front Load Washer
Machine squeals when filling
Hi just read your posting.Now what temp of water are you selecting for the wash cycle,is it warm, cold, or hot.Try this,Select hot fill then select cold fill and please reply on whether the squeal stops on either hot or cold fill.Looking forward to your reply.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
My LG TROMM Washing machine squeals when it is filling the water into the drum. I wonder if anyone knows the part that needs to be replaced so I can purchase it and replace it myself. I'm guessing it might...
You are right! The valve is bad not opening all the way. Get the model # and go to PCAPPLIANCE.COM and order a new valve. Two screws in the back and you slide the top back and up to get it off. Then you will see the valves.
Jan 21, 2010 | LG Washing Machines
Squeals when hot water inputs
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 10, 2010 | LG WM2101HW 4.0 cu.ft. Washer
The washer squeals as the water is filling the tub and continues through most of the cycles. As the machine agitates quickly, the squealing stops. However, it squeals at the end of the cycle.
Sounds like the pump.  When it first fills the pump recirculates the water, then it comes on at the end of each cycle to drain the water.  The pump is on the bottom of the machine, on the right side.
Dec 19, 2009 | Fisher Paykel EcoSmart GWL15
LG f1256qd front loading washing machine, during fill up it makes a high pitch squealing
Sounds like too high water pressure, could also be dirt in fill valve / faulty valve. Good luck
Oct 03, 2009 | Washing Machines
During fill up, machine makes a high pitch squeal
Have you checked your hoses for a leak? We could pin point which hose was leaking by trying all cold, then all hot...although changing both at the same time and on a routine basis is a great idea.
Aug 18, 2009 | LG WM-2277HW Front Load Washer
Washer makes a loud squealing sound when starting water cycle
This means the electronic water valve has gone bad and will need replaced by a technician. Hope this helps, please rate my solution.
Jan 09, 2009 | LG WM-2077C Front Load Washer
LG WM2301HW Front Load Washer Logo
320 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
