Question about Lexmark Office Equipment & Supplies
Cartridges wont come to centre - Lexmark Office Equipment & Supplies
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
My HP L7680 has stopped printing black. The black cartridge is OK but I have replaced it with a new one to be sure. There is no error message but it just prints all other colours but not black?? HP...
Dear Its,
4 tray cartridge printer, i request you to please by orginal black cartridge ( No.18) and insert into the tray, def. it will start printing ...also if any damge from any relay or cartridge the printer wont work.
So the problem from cartridge only. pls try new.
Jun 28, 2009 | HP Officejet Pro L7680 All-In-One Printer
I recently changed the colour cartridge and now the printer wont print colour. Black works - ish. I have troubleshooted and did everything recommended eg clean print heads, nozzles, align heads etc....
Please see the online guide at:
http://support.epson-europe.com/onlineguides/en/sc48/refg/ref_g/
and click on Replacing Ink Cartridges. To change a cartridge before it is low or empty you must press the maintenance button AND the power button at the same time, or use the print utility.
If the new cartridge also fails to produce print, come back with a new comment for further help.
Apr 13, 2009 | Epson Stylus C48 InkJet Printer
Hp deskjet 3940 printer light just blinks.It will not do anything else.
in this printer only one LED present that blinks and two kinds of blinking one slow and other fast blinking
So if slow blinking inyour printer then this may be cartridge error, if you are are using refilled ink cartridge so please change change that one.
and if fast blinking in your printer then you cannot do anything.
in last go to AN Authorised service centre(to know the address of AN Authorised service centre in your city please visit at http://www.hp.com ).
thanks
ttyagi
Jan 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
Epsonc43sx problem
u just do a thing.just press the paper load button when the printer in power on that time the catridge will move suddently remove the ac power pin of the printerr while the catridge tray on centre afterwards u can remove the catridge and install new one
Jun 18, 2008 | Epson Stylus C43SX InkJet Printer
Canon pixma ip4500
u should carry the printer to Canon Care Centre, they will check the case and if found that the Cartridge u r using is Genuine your Cartridge will be replaced.
Regards,
manoj joseph
+91 9352008418
Jun 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer wont function correctly...
so you need to change the black ink cartridge. just shift the cartridge to the centre and change it.
Jun 01, 2008 | Brother MFC 3100C All-In-One InkJet...
I need directions on how to replace my ink cartridge on a HP officejet v40. My husband purchased this printer, but I don't know when, and he has since passed away. The support on the phone wouldn't help...
Hi, normally when you open the printer the ink cartridges will go to the centre and you can unclick the cartridges to replace them. On some printers you need to press a button which brings the cartridges to the centre so you can replace the cartridges.
May 13, 2008 | Office Equipment & Supplies
Wont print
Error 1200 is a jam, are you sure there is absolutely no jam? Open up unit and really closely inspect with a torch if you have to. Jams can be so very tiny...the fact that the cartridge wont centre itself suggests a jam too.
Jan 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
