Question about KWorld VS-USB2800RF USB2.0 TV BOX, NTSC only, MPEG 1/2/4,FM Graphic Card
Hi! i have a tuner tv box usb2.0 tv box TNF 5535-MF .THERE NI SOUND .could you please help me .
  • 22 Answers
This might help No Sound
Posted on Mar 12, 2011
How connect toshiba tv to samsung home cinema whit hdmi? i connect but still no sound. i want watch tv but listen in cinema sistem
the hdmi jack on the tv is an INPUT jack, not an output. to use your reciever for tv sound, you have to find the audio output on the tv (most do not have an audio out, but some higher end tv's have a fiber-optic digital out, which may or may not be compatible with your surround sound reciever)
if your tv does not have an audio out, the only way to get the tv sound into the styereo is to use a tuner box, like a cable box or satelite box. tuner boxes always have either hdmi or stereo audio outputs.
to use hdmi with your surround sound, you are supposed to run HDMI OUTPUT from the tuner box or disk player into the HDMI INPUT of the stereo, and then run the HDMI OUTPUT of the stereo into the HDMI INPUT of the tv.
Mar 12, 2011 | Audio Players & Recorders
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
No sound from the tv tuner card
1. Did the sound ever work?
HARDWARE:
2. If so, then the short cable that is connected from the TV card to your computer sound card came loose.
3. If it has never worked, then you need an audio cable to connect the TV Audio OUT to your Sound card audio IN.
SOFTWARE:
4. If it has worked and the cables are ok, then the "Audio IN" mute box is checked. Double-click the "speaker" icon on the lower-right of your desktop. UNcheck any of the audio mute boxes.
It should work now. If you need clarification, please reply.
Hope this helps!
Sep 03, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 internal TV tuner card sound problem
hi,
try on a different slot on the pc or if you have another pc try using the tv tuner on another pc
if it still doesn't work your tv tuner card is bad.
further queries are welcome
Feb 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problem with Plasma TV Philips 37FD9944/01S
i hve no reciver box but i done my job here plz help me in this problem ni reciver box then how i repair this plazma flat tv model no 37fd9944/01s help me
Nov 05, 2008 | Televison & Video
Hitachi tv no picture
It sounds like the tuner demodulator has failed. Many times I have found that it is cheaper to buy an external hi-def tuner than repair the one that is in the set. The fact that the tuner is finding channels but not displaying them is a good sign that the demodulator has failed. In one case I had with Sony rear projector, it would have been $800 to repair the internal hi-def tuner and the customer can buy an external tuner for $100-$200. Sorry if this is not the answer you wanted; if you fel this si a good response to your question, please be sure to rate me,. Thanks!
Oct 22, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Tv on hp media center
Have you gone through the media center installation process and got the tuner / tuners setup properly?
Jul 03, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Humming from HLP5063WX TV and no color
Initially, it would be suggested to try viewing a DVD or a VCR and determine if the humming sound & no color persists. If yes then conclusively, there is something wrong with the TV. If none, then the source of the humming sound would be the tuner section (internal to the TV) or your cable TV/aerial or your cable box/decoder.
If the humming sound and no color is present in either TV tuner/channel and with an external video source such as a DVD, then chances are that a large filter capacitor inside the TV needs to be replaced. It would probably be in the power supply section AC side.
If the humming sound and no color is present only on TV tuner/channel, you would have to check your TV signal source. If you are using an aerial, it may require re-orientation; if it were a basic cable, then you would need to consult with your cable provider; if you are using a cable box/decoder, then the problem could either be with the box/decoder or again your cable provider.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Televison & Video
KWorld VS-USB2800RF USB2.0 TV BOX, NTSC only, MPEG 1/2/4,FM Graphic Card Logo
333 people viewed this question
Top KWorld Computers & Internet Experts
David Payne
David Payne
Are you a KWorld Computer and Internet Expert? Answer questions, earn points and help others
