Question about Miele Dishwashers
Intake water light is on - Miele Dishwashers
  • 827 Answers
Have you checked the water line feeding the dishwasher? you have some problem with water getting into the machine.
best regards
Ck
Posted on Mar 12, 2011
Is there a recommended amount of water that should be drunk by a 60 year old male per day.Is it the same if Robinson orange squash added?
the amount of water for people is between 11/2 to 2 litres per day However that will depend on the temperature and the body movements
for example on a cold day but with a strenuous work out , the water intake still has to be high
on a cold day rugged up the intake will be less
On a hot day it has to be high and if there is strenuous work happening even more than the 2 litres
As the body uses electrolytes those electrolytes become depleted with the water intake so rehydrating fluids are required as well
any added flavouring helps with the taste of water but it is the quantity that is important
body waste water color is the test for hydration --straw to dark tan or brown indicates insufficient water intake ( blood from the dry kidneys) light color to almost clear indicate s good water intake
Oct 17, 2017 | Orange Pool & Spa
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 17, 2013 | Water Heaters
I have a model 6G40PVW-40F water heater and we have no hot water... the thermostat light on warm/vacation is on and so are 2 other lights...If I diconnect it and re-connect it then it will start..the gas...
Most gas water heater problems today can be solved with yearly maintenance that includes cleaning burner parts, clean air intake, check venting, check electrical connections, bleed gas line, and check gas pressure.
Gas water heater manuals recommend yearly maintenance by service technician.
In past years, gas water heaters required less maintenance, but they were less energy efficient and more dangerous to operate.
Sounds like you have Intellivent gas control valve thermostat.
Open following link to identify gas valve and see error codes:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Error light on vacation + 2 other lights = 3 possible conditions:
1) Wiring error: check outlet with circuit analyzer:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
2) Pressure switch tubing not connected, air intake obstructed (clean intake), or vent exhaust obstructed (check for proper venting).
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
3) System in lockout: Low gas pressure, hot surface igniter not positioned correctly.
You can do some of this yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to clean intake & drain, light is on and
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jul 18, 2010 | Miele G848I Dishwasher
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Intake/drain light on
This happens to me occasionally. There is a long thin bottom panel along the floor. Then there is another panel behind it. Behind, there is a pan that holds water. If too much water gets in that pan the intake/drain light comes on. Take those two panels off, feel in the pan, if there is water pooled, then wet vacuum the pan dry. That solved my problem and saved me about $200. I got that info from the miele advisors. That is what it is about 90% of the time if it isn't that intake valve.
Aug 13, 2009 | Miele 23 in. Novotronic G841 Built-In...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Mieli water-intake light comming on?
I think it's regular salt, yes, but I've never bothered to fill mine.
Have you had a dishwasher previously? If not, check the tap where your washer gets its water to make sure it has proper water preasure. If the washer doesn't get enough water it will stop.
In my kitchen there is a separate little knob on the tap to control the water to the dishwasher. this has to be open. Mine has hot and cold selection, but only cold is connected so if I turn it on hot the washer gets no water
Nov 07, 2007 | Dishwashers
Dishwashers Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
