Question about MSI NX7300LE-TD256EH GeForce 7300 LE, (256 MB) PCI Express Graphic Card
Hello, Sir my msi graphics card stoped display ,,i don;t know whether it needs vga bios update or what. when i saw it by turning my pc off it got hot . some times it gives the display but everything big like no drivers installed and some times ripples blue and green colour, and now it has totally blackout screen. plz help me out i shall be very grateful . ur's sincerely Rafiq Kundi.
    Sergeant:
  • 146 Answers
Hi mrafigkundi,
because you chose to repair by yourself then i will suggest this steps
#1. see if you plug cable data from monitor to VGA correct. if yes...
#2. detach your pci express graphic card from motherboard.
#3. see if some component burn, sometimes it located near pci slot, if it does then you have to change it.
#4. if none of component burn, put again in your CPU
#5 your problem can caused by memory chips defect, you can test it with memory test, its running under dos so you have to reboot it with bootable CD and run VGA memory test.
Posted on Mar 12, 2011
When i turn my computer on the display comes on for only a few seconds then it says no signal when i restart no display
Hello Heidi, you may have two VGA port. my guess is that your monitor is on the main board VGA, remove the VGA connector and locate the other VGA port. usually the graphics CARD. need to connect it there.
Jan 02, 2014 | MSI Computers & Internet
I got a PCIe Graphic card but apparently even after i have fitted it perfectly into the slot, the display won't switch to the graphic card from the onboard video.please help.
You will go to BIOS SETUP and press F2/F10/ Dell
Disable on Bord VGA or set the graphics piority
http://www.pcbuyerbeware.co.uk/BIOS.htm
FOR VGA
http://www.pcbuyerbeware.co.uk/AGP.htm
1st pci slot
2nd on-board VGA.
Follow link
It will help you.
Regards
Shibuda
Jan 05, 2011 | MSI 945GCM5 Motherboard
Vga drivers
You can check in BIOS and see whether the on-chip video has been turned off if you are using the graphic card not embeded on motherboard. Then you can update your graphic driver if necessary. Boot in safe mode if your monitor is not showing anything.
Oct 11, 2010 | Computers & Internet
My screen stoped working and it is on the lowest color quality and zoomed in to 800 by 600 pixels and i cant change it... can you help me?
Sir you need to reinstall your Graphics Card driver or VGA. For that follow these steps:
  1. Right click on the "My Computer'' icon.
  2. Click on " Properties".
  3. You'll see the System Properties pop up menu,Click on Hardware tab.
  4. Click on Device Manager.
  5. Device Manager pop up window would appear on screen, on that click on Display Adapters.
  6. If it shows your VGA card there then Right click on it and then on Update Driver.
  7. Or if it don't Right click on it and Uninstall it and then restart your computer.
  8. Then install your Graphic card from either Disc or any other file in your system where you placed the VGA driver.
  9. Make sure you install the compatible version for your windows.
Aug 04, 2010 | Microsoft Windows XP Professional for PC
No signal problem with xfx 9400gt fatal1ty
Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
Jul 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
NO DISPLAY
did you hear any beep sound, when you try to switch ON the computer..?
Thank you..
May 08, 2008 | Computers & Internet
Xbox 360 to pc vga
You need to connect your xbox 360 to your monitors VGA port,not your graphics card. The VGA on the graphics cards are outputs for the PC.
Mar 07, 2008 | Microsoft Xbox 360 Console
I want to dowload VGA from MSI Board MS-7142
All drivers and utilities here :)
http://global.msi.com.tw/index.php?func=downloadindex
Dec 28, 2007 | MSI K8MM-V Motherboard
MSI 865 MOTHERBOARD VIDEO / DISPLAY / GRAPHIC DRIVER
Here you go..
http://global.msi.com.tw/index.php?func=proddesc&prod_no=41&maincat_no=134
PS:There are many 865's so i figured out it could be this one..Otherwise you can search the same site and you will find it..
Oct 31, 2007 | Computers & Internet
MSI NX7300LE-TD256EH GeForce  7300 LE, (256 MB) PCI Express Graphic Card Logo
190 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
