Question about Dryers
Kenmore dryer drum felt
I am trying to install a felt on my dryer. I am wondering if the colored threads of the felt go on first up to the center fold. Or does the other side of the felt go on first and the edge of the drum goes up under the center felt.
    Genius:
  • 1,028 Answers
If i remember seam closest to edge goes toward center of drum ..should have been instructions in bag
Posted on Aug 01, 2008
Leather strip came off dryer. Now seeing shiny fibers on clothes. I'm wondering what the fibers are and if they are dangerous. Dryer is a kenmore from the 80s or90s
The fibers are felt and theirself are not dangerous...however they were secured to that leather strap that came off and that leather strap and the felt fibers comprise the rear drum seal and now their is a gap in the drum because that felt seal has come off...with that felt seal off their is a great possibility of clothing falling through the gap and damaging the components of the dryer (and ruining your clothing)...it is highly reccomended that the felt seal is replaced on the dryer drum.
GENE
Sep 08, 2011 | Kenmore Dryers
Good Morning: I have an older Kenmore Dryer with the serial # of : 77982600 and the belt broke. I can get the new belt but am wondering how it goes on. Do I have to remove the felt belt on the backside?...
dont mess with the felt on the drum... pop the top of the dryer. 2 clips hold it down.. use a screw driver to pop it. then take out screws on the front and bottom to remove the front part of dryer with the door . now put the belt around the drum put front on. then comes the fun part feeding the belt through pully tensioner good luck remove back to get to belt pully /tensioner
Aug 16, 2010 | Kenmore Dryers
Found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
Apr 26, 2010 | Kenmore HE5
Brown streaks on flat, thin items like pillow
Hi Witt and welcome to FixYa. I am Kelly.
The brown streaks are most likely rust. There are drum seal replacement kits you can buy to start anew. The streak source need to be identified. If the drum is rusted your going to have to sand and paint it with an enamel appliance paint. However.... if it is the back of the cabinet that is the source of the rust in the felt seal rub area if you do not allow the paint to dry well before reassembly it will end up flaking off on your clothes.
Here is the drum seal with adhesive:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
Once you in there I would replace the belt and inspect the drum rollers.
Belt:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Whirlpool-Dryer-Belt-item-number-AP2946843.aspx
Rollers:
http://www.appliancepartspros.com/part_details.aspx?part_id=3098345
The belt I would replace... Just make sure if you attempt repair that you NOTE the routing of the dryer belt through the idle pulley to the motor pulley.
If the rollers rotate freely with no teetering froward or aft and do not have any flat spots you do not have to replace them.
Appliance paint by color needed:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Appliance+paint
Thanks for using FixYa
Kelly
Mar 14, 2010 | Kenmore 62602 Electric Dryer
Clothes get caught between the drum and the dryer wall, and they tear as the drum turns
need to change the felt strips on the dryer,take the drum out and check the front and rear felt strips that the drum rides on
Nov 02, 2009 | Kenmore Dryers
Rust colored spots on collared shirts coming out of dryer
the fabric is called a felt seal or just a felt. this can be seen after removing the drum or by opening the top of the unit. scraping noises are a common problem when this part is gone.hope this was a help
Thanks
Oct 11, 2009 | Kenmore Dryers
Brown marks on the clothes
Yes, the felts are what seals the unit and allows the drum to turn without much heat loss. The felt can become damaged and the clothes will get caught between the drum and the housing leaving these marks.
Apr 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Drum Felt
i know have to ck myself on those sometimes the stitch closest to the edge of the seal goes toward center of drum..you will also have to stretch the seal around edge of drum 4 hands make it easier
Aug 01, 2008 | Dryers
Noisy Dryer Drum - Squealing/Grinding type Noise.
I have a Kenmore Stacked Washer/Dryer (Model 417.91702000) that has had the same thing happen. I have replace mine twice . . .It is the rear dryer bearing.
You can purchase a kit that contains everything to replace it.
You have to work from the front, all the way to the back.
Make sure that you also check the felt pad glide on the front door panel (the drum rotates on this). You may need to replace it also, it should have teflon pads built into the felt that the drum rests on . . .
Jan 21, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
109 people viewed this question
Top Dryers Experts
