Question about Zhone 6211-I3-200 Router
MTU I can not log into xbox live because my mtu setting has failed. I also cant seem to log into my router to see if I can change that setting. How can I do this?
  • Anonymous May 22, 2009
    My ZHONE 6218 router with Consolidate Communications suddenly quit allowing me to use XBOXLive and it's saying that the MTU setting is too low.
    My "protocols" on the router (DSL modem?) MER and Bridge. Please
    Brigadier General:
  • 6,966 Answers
Hi again,
My sincere apologies. Power interruption and it took some time for the gen to kick in.
With your indulgence, I would post here my additional inputs.
Initially, I am of the opinion that your Zhone is not acting as a router but a modem or even perhaps as a bridge. Having said that for the xBox and your Mac to work simultaneously, you would need a dedicated router. This is further evidenced by your Default Gateway which i believe is your ISP/s.
Additionally, this is also the probable reason you can not access the Web Interface. Normally the web interface address is identical to your Default Gateway address.
Would appreciate your thoughts.
Again my apologies for any inconvenience.
Kind regards and thank you for using FixYa.
Posted on Aug 01, 2008
I can't connect my Xbox 360 into LIVE because the
This option is available via the web interface under the WAN Settings screen.
Nov 29, 2009 | 3Com OfficeConnect Wireless Router
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
I cant access xbox live because my mtu is below 1364... how can i change this setting
it's not your MTU setting, you actually need to open some ports in your modem or router. Xbox can explain the port numbers, and www.portforward.com can help with the details.
Aug 02, 2009 | 2wire (1000-400108-001) Router
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
I cant connect to xbox live cause of my mtu setting
you have to log on to the router and under the WAN mode, you should have the option of changing the MTU. IF you have not made changes to the router settings, type http://192.168.0.1 in your browser . In the page that comes up, type in username as admin and no password.
This should take you to the browser login page.
Hope this helps
Thanks Ranjit ranjit@supportminds.com
Jun 16, 2009 | D-Link DI 514 Wireless Router (DI-514)
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Mtu failed
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
May 02, 2008 | Computers & Internet
MTU fail actiontec gt704wg
I opened my xbox 360 and i did not see a switch any where. don't do it its a lie.
Jan 06, 2008 | Actiontec (GT704WG) Router
XBox 360 MTU Failed with Router
MTU of 1500 is the standard TCP/IP message length. Only MS Vista allows that to be changed dynamically. If your ISP uses 1500 then you need to use it too. Your Xbox protocol may be blocked by your ISP. You may want to give them a ring...
Jan 04, 2008 | Linksys Wireless-G Broadband Router
Zhone 6211-I3-200 Router Logo
550 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Justin
Justin
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
