Question about Panasonic Viera TH-42PZ80U Plasma TV
I went to turn it on and the red ligth went out.
  • 83 Answers
Try and unplug the cable from the socket, then replug the cable to socket and finally use your remote power to turn it on
Posted on Mar 12, 2011
The tempeture ligth start blinking red in the morning and it beeps about 6 times and then the ligth turns off
Check coolant level in bottle.
Check for updated CTS ( Coolant Temperature Sensor.) in hose at rear of cylinder head.
Check for coolant creeping up loom from coolant res; bottle.
Check Grounds under battery.
Jan 05, 2011 | 2000 Volkswagen Beetle
I just recently bought a house with a Tappan Gas Stove model TGF657 and I am having problems lighting the oven. I have never used or seen a gas stove before.
will be very careful went lighting the poilt ligth.ok make sure the gas it on and the knob on the sotve is off raise the hood you should see the poilt ligth between the burners ligth it with a matche in each one go to the bottom open the door there a poitl ligth at the back to the top ligth it
Oct 17, 2010 | Tappan TGF657 Gas Kitchen Range
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
O.k i try to fix my jeep i check the engine ligth i ready change all the sensors what the engine ligth say aand still the same went i running just turn off
You knowed what code are there? Read the Check Engine Codes
If you change the sensors, Reset the ECU, sometimes they keep stored in the mmeory.
Hope this help; good luck (remember rated this help).
May 11, 2010 | 2002 Jeep Grand Cherokee
Warning red ligth
you can have the vehicle check for code with a hand held device then you will know what sensor cause the light to come on.
after you make the necessary fix you can erase the code then the light will turn off
Mar 03, 2010 | Mitsubishi Cars & Trucks
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
My nec vt46 does not want to turn on
You need to check the manual. It will tell you at the rear what the different lights mean.
Apr 13, 2009 | NEC VT460 Multimedia Projector
Red crt tube
IT IS PROBABLY TIME TO CHANGE IT OR THE LIGTH DIFFUSER THAT SENDS THE LIGTH TO THE TUBES OR LAMPS IS MALFUNCTIONING
Oct 01, 2008 | Philips 60PP9202 60" Rear Projection...
Hitachi T.V.
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Jul 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Panasonic Viera TH-42PZ80U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
