Question about Wellgo RC-713
Trying to locate a manual for the Wellgo RC-713 pedals..having problems disengaging easily from pedal.
    Brigadier General:
  • 8,546 Answers
Just loosen the screw on the back a little. Not so far that it falls out. Squirt some lube in the guts, too.
Posted on Mar 12, 2011
Disengaging mechanisam for bobbin winding Foot pedal not sensative enought
Foot pedal carbon brushes may be worn and need to be replaced.
Nov 12, 2015 | Sewing Machines
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Wiring diagram model 7466 i am trying to reconnect a foot pedal on my singer sewing machineu
The foot pedal is generally plugged in on the right side of your machine. There should be a hole that matches the end of the plug. The user's manual is available as a free download on Singer's site.
Sep 22, 2014 | Singer Sewing Machines
Can you adjust the clutch pedal on a 1990 full size bronco
The clutch is operated hydraulically, and there is no adjustment. If your problem is that the clutch will not disengage or is hard to disengage you may be low on fluid or have air in the line. There may be a leak either at the master cylinder or the clutch slave cylinder. Bleeding the slave cylinder may restore pedal pressure. If the problem is that the clutch engages high on the pedal the problem is likely a worn clutch disc.
Jul 30, 2011 | 1990 Ford Bronco
My Boss RC-2 Pedal is having a problem with the output. With the volume turned up to max, the signal is suddenly extremely faint on can only be heard if there is silence in the room. Even the backing track...
Most PROBABLE is the output jack either has been broken (common due to mishandling and accidents with cables such as stepping on the plug while plugged into the pedal) or the soldering of the jack in the pedal has broken loose. Less common is a circuit board crack in the vicinity of the jack. Open pedal and inspect for the above suggestions.
Mar 11, 2011 | Roland Boss RC-2 Loop Station Stompbox...
I have been sold Performance Classic road Cleats as compatable with Wellgo R3 Pedals. They seem to fit,but I dont want to get this wrong. Can you confirm compatability? Thanks, R
R3's are Look-compatible.
You could call Performance directly and they would tell you (800 553-8324).
The "Look" style doesn't have a lot of variations (zero, actually).
Feb 19, 2011 | Cycling
My left pedal is broken because it's really worn inside the pedal and I need to replace my pedals.
There are two thread sizes for pedals, make sure you get the right ones. Take the old one with you to the store.
You'll need a crank/pedal wrench to take the pedal off. The gap is too smal to get a normal size wrench in there, but you might get lucky.
Use some penetrating fluid on the thread and leave it overnight before you do it, as they are notorious for getting stuck on. Have a friend stand on the other pedal to keep it still, and undo it.
Tighten up the new one, remember the threads are backwards to normal tightening. Happy riding - vote for me please :)
Jul 02, 2010 | Wellgo 12 Crank Silver Bicycle Bike Pedals...
I have an audi a4 1998 and i have been converting it to a s4
Sorry!.. The information you seek is 'PROPRIETARY'.. meaning it's a secret by the manufacturer. If you really want to fix it yourself?, then contact the manufacturer.
Sep 10, 2009 | 2002 Audi S4
Can they be serviced or is it not worth it?
Mixed opinions at this site:http://www.mtbr.com/cat/drivetrain/Pedal/wellgo/wpd-823-clipless-mountain-pedals/PRD_428656_135crx.aspx If you have a thin wall deep socket the right size you can service the bearings. I don't know if parts are available. They are considered as entry level pedals.
Aug 11, 2009 | Wellgo Wpd 823 Clipless Mtb Pedals
Wellgo RC-713 Logo
265 people viewed this question
Top Wellgo Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Wellgo Cycling Expert? Answer questions, earn points and help others
