No Digital V Signal. I have an HCT plasma HPP-42HCB TV. Connect to a digital attena, no cable or Dish. All local digital channels were coming in fine for a year then nothing one morning. Menu, Channel then Auto Search...produces this message "DTV Air Scan" & "DTV 2" & a status Scan bar that's stuck at 53%. Cannot get it to stop or reset. Have to turn the TV off the on the process reproduces the same results. Unplugged the TV for 15 minutes but no change. All other inputs work fine...VCR, my PS3 via HDMI. Just not Digial TV.
  • 90 Answers
SOURCE: Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Posted on Jan 31, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: Vizio TV says no signal on digital channels
add each chanel manually
Posted on May 30, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
I need the programming code to my ATT, S10-S4 remote to control my HCT TV, Model HPP-42HCB.
The codes are stored in the remote. If you are unable to control your HCT TV, you may have to substitute a programmable remote to find an appropriate code.
Jun 20, 2015 | Televison & Video
Why does LG tv shows no signal fot local nbc channel
Not sure how you are connected to receive the signal, but if you are not using a cable box and going off air, then either the signal is not coming in from NBC, or your antenna needs adjustment. IF its over the air, its also a digital signal which will tune to lets say channel 4. For digital it will be 4.1 or 4.2 etc.
If you are using a cable/sat box to then connect to the TV, call the provider and ask.
Aug 26, 2014 | LG 42LC2D 42 in. LCD HDTV
I have a 42" HCT HPP-42HCB TV S/N 42HDT9MUH046 no picture but has sound
I assumed its plasma TV..
If it is plasma you have faulty y-sustain board..try to replace it to fix the problem
Nov 06, 2012 | Televison & Video
HCT TV Model HPP-42HCB Direct TV Remote code needed.
If code not found look to see if this remote has a search mode where every possible code it has can be tried one at a time---it may just not have the code and in that case you are out of luck.
Apr 23, 2012 | Televison & Video
I have an 42" HCT TV model HPP-42HCB. When the TV
same thing with mine same model same issue, then it stays with the green light as it would be if it was on and working, and wont let me turn it off then, with no pic left or sound, its killn me, let me know what you find out!!!!
Aug 02, 2011 | Televison & Video
Do I need some cable box to connect my digital plasma TV to the cable signal? Or can it use the signal without a box?
The cable box will only be needed if you're going to subscribe to receive digital channels. If not, the plasma should be able to receive all the analog channels available with your current subscription.
Sep 24, 2010 | Panasonic TH-42PC77U TV
Lookig for Manual for 42in plasma HD TV. Model # HPP-42HCB Made in Korea. And also Remote control
for your manual just click at google .com and then manuals. for your remote you can buy the universal on best buy walmart or frys
Aug 11, 2009 | LG 42LC2D 42 in. LCD HDTV
Setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
Feb 23, 2009 | Sansui HDLCD3210 32 in. LCD TV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
