Question about Moen Muirfield Kitchen Faucet with Side Spray
Just purchased these Moen taps and on installation the quick connect will not stop leaking around the thread connect. Is there suppose to be an O ring in there? This one does not have one. Model is Moem Muirfield dsidey@hotmail.com
  • 718 Answers
If you just purchased this unit take it back it's obviously missing parts, you payed good money for the unit get it complete!!!
Posted on Mar 12, 2011
How to install moen adler thread end nozzle with adaptor
I have encountered different threads in different spouts, both old and new work. Yours may have a thread that is different from the adapter.
Feb 12, 2017 | Moen Plumbing
HOW TO CONNECT DISH SPRAY
My first question is it a moen factory dish spray hose for that model? If not and it is a universal type it might not work at all on the moen. If it is a true replacement part then check the threads both on the faucet body and on the hose end to make sure they are not damaged or cross threaded. If the original hose was put in and cross threaded the connection on the faucet body the new hose will probably not screw on. If this is a quick disconnect model make sure that the faucet body connection is clean and place a small amount of faucet lube on the hose connection to help with installation. Sometimes what might happen when replacing a quick connect end is the old hose left bits of O-ring in the faucet connection which will not allow the new end to seat properly.
Aug 29, 2014 | Moen 7560BL Extensa Matte Black Lever...
How do remove the faucet cover of a moen 7594EC
MOEN Motionsense Faucet Leaking????
Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
Screw the nut back into place with your hand, then tighten with a wrench.
Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
I just installed a new Moen Model 82496 single handle shower faucet and it won't stop leaking. I adjusted the white gear every which way and nothing will keep it from leaking. It varies for different...
When installing plumbing fixtures, you should always use either plumbers putty or Teflon tape around the threads where the two pieces come together. Without it, leaks are very possible. More often than not, you get leaks.
Jan 07, 2018 | Home
I have just bought a miele 5100 dishwasher, my husband connected it, but the inlet hose connection that goes to the water supply, which has a large plastic piece on it is leaking, you can click it open but...
the big box on the tap end is called the aqua stop fitting. If it leaks around the tread make sure there is a washer in the big nut that screwas onto the tap. The tap might be old and not true on the fase. You could try some thread seal tape on the tap thread. good luck
Feb 10, 2011 | Miele Dishwashers
Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Moen Hand Shower repair
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Apr 13, 2010 | Moen 3867 Four Function Hand Shower With...
Moen Muirfield Kitchen Faucet with Side Spray Logo
292 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
