Question about Grohe Home
I have a grohe avensys shower and even when the dial turned to its hotest its just lukewarn I need to adjust the setting
  • 718 Answers
Good answer! Go for it and also you might want to up the heat setting on your water heater.
Posted on Mar 12, 2011
Grohe avensys dripping
Hi Bryan,
The leak you're seeing originates at the hot / cold water valve(s) itself. Most newer homes have valves that automatically adjust the temperature of the water to prevent scalding. Your Grohe Avensys, like many reputable makers, have warranties on their products and may make replacement parts available for free - if you are still under warranty - by call their customer support lines.
Generally, you will not be able to get free replacement parts at a hardware store, plumbing supply store, etc. You must call the manufacturer directly. Of course, you will have to pay for these parts at those retailers - if the valve is out of warranty, been replaced by the manufacturer under warranty previously, etc.
Your first step will be to identify the valve model. This information may be near the manufacturer's name - or may require locating the manufacturer's web site for visual comparison. Either way, you'll probably need to contact the customer service representatives to get help with replacement parts. They should be able to select the parts that you need to solve the problem and provide them along with printed removal & installation instructions.
Contact links for Grohe USA & Canada
Contact links for Grohe UK
I hope this helps & good luck!
Aug 31, 2012 | Home
Grohe shower mixer, water always warm, never hot, even when turning temp up ?
There is a hot temp limiter that comes from the factory set too low, often. typically you remove the handle and there is a limiting ring located under it that needs adjusting. This is a very common issue on most brands, deals with lawsuits.
Jan 06, 2011 | Grohe Home
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Jul 29, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Adjusting water flow
if you are using a mixing valve it is pre set so as to not burn your self but if you wish to set it on the dial depending on which one you have, some are flat tip screw driver some have plastic cap on it turn on the water and set to your desired temp by turning clock wise or counter clock wise
Apr 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Home Logo
435 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
