Question about Garden
2005 model Murray 42 " cut with 15 hp OHV engine.
  • 718 Answers
Oh yes they were right !! This happened to my unit last summer, those intake and exhaust have to at least checked every time you tune up so for most that is a seasonal check to keep everything in check.The magnet inside mine got ripped off the inside wall of starter casing. Go to smalleng.com they have a video for this and all you have to do is find out the gap numbers, that local repair shop of yours will be happy to give you those numbers. Now get er done!! Good Luck....
Posted on Mar 12, 2011
Testimonial: " I am used to the old type engines and never thought of adjusting valves. The repair shop said the would do it for $32.50 and show me how. Thanks ;-)"
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Motor stalls after 15 minutes of cutting on my murray 17.5 ohv 42 inch riding mower
plug needs replacing, im guessing that it restarts when it cools down.
also check the oil level. it has a low oil cut out. but my money is on the plug or coil
Jul 14, 2012 | Briggs & Stratton Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
Engine ran and now lost spark!
Look for a fuse and see if it has blown. It will look like a fuse you use in your vehicle. If blown put in a new one. If it blows again look for a bare wire that could be shorting out.
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
