Question about Dryers
Bosch Classixx WTL6003GB. Fails to heat. I have replaced the reset button & the element, to no avail, whats my next fail possibility? I notice now that the small printed circuit board on the top right of the machine (as you look at it from the front) seems to be brown/discoloured around two of the resistors, could it be this, and what is its function? Dest regards dave
Hi I have one of there and it won't start. No light on or nothing checked the fuse in the plug and that's fine but when I took the lid off I notIced the same 2 resistors on the right are brown and discoloured does anyone know what resistance they should be so I can try to see it that's what's causing the problem
Thanks rhys
Posted on Dec 31, 2011
  • Dryers Master
  • 1,527 Answers
Hello dave, have you checked the heat sensors there will be 2 of them get a multimeter test them both if 1 is faulty change both of them if you have test the resistors desolder 1 end and lift it away from the board so you get a proper reading from the board hope it helps
regards
shaun
Posted on Mar 12, 2011
    President:
  • 3,074 Answers
Http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Why does my bosch classixx maxx freedom performance dishwasher not heat the water
I would suspect the heating element have failed , calling a service repairman might be your best recourse .
Jun 08, 2016 | Bosch Dishwashers
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Water not heating,element testing ok
Hi there
if element changed recently when it failed it may have damged heater relay on back of control module if the heater or this has failed you will only get a cold wash on any prog they will take nearly four hours to finish if it takes normal time to wash but doesnt heat will probably be an ntc fault this is attached to heater and easy to replace.
Dec 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch dishwasher dosnt get hot the element is ok
Does it have a thermostat that you can set the temperature seperately? If so, i would check the over temp thermostat firstly.(possibly it has a push button reset.) Normally found near the element,If good, check the temperature thermostat.Unfortunately, it requires using a tester to check for continuety.and resistence. Normally, that should solve the problem.(Im taking it that the element is ok as you have stated).
Nov 12, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Problems with washing machine cycles
does it heat up? if not the element has gone and needs replacing. try it out on a cold 30 wash to see if it goes through if so element probs.
May 29, 2007 | Bosch Classixx WVF 2402 Front Load...
Dryers Logo
87 people viewed this question
Top Dryers Experts
