Question about Tascam Dp-02cf Digital 8-track Recorder
When setting up for recording. I have the sound output to my speakers. i dont get sound until i press the record/play button. How am i suppose to know what it sounds like before i start to record?
    Brigadier General:
  • 8,546 Answers
Read the manual.
Register and download the manual for free audio.manualsonline.com
http://music.manualsonline.com/manuals/mfg/tascam/dp-02cf.html
http://dl.owneriq.net/5/596f1517-7f90-4719-9803-1792891188c1.pdf
Page 16 Press the Record key by itself to place it in Record Standby mode.
Posted on Mar 12, 2011
Problem with recording/playback
If it plays back a pre-recorded tape OK, then the tape head will be good. If it doesn't you might have problem, with either the head or the pre-amp stage.
However if it is playing back OK but not recording, then you have problem in the record circuit. Some tape decks physically switch the circuit when you press record. Pushing the record button will cause a switch to move position. In some cases dirt or dust can get into the switch and it doesn't connect properly. Switch cleaning fluid will correct the problem.
However the record circuit itself could be faulty. Perhaps an IC has developed a fault on one channel, which will need to be replaced.
Watching what happens when you press record with the top cover off, showing the workings, might point to some movement of the mechanism to reveal a faulty switch.
Jul 07, 2016 | Audio Players & Recorders
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Downloaded songs appear in iTunes library but won't play on comp
I had exactly the same problem and followed the OP's solution, which worked, but I couldn't hear the track as it was being recorded.  So I tweaked the solution.  If you do the following, you don't have to keep changing System Preferences as you switch from record to listening:
Go to System Preferences, press the Sound icon, and click on "Sound Effects."  Then select the drop down menu and select "Play alerts and sound effects through selected sound output device" rather than the USB choice.  Then click on "Output" and select how you want to listen; I used speakers so I selected "Headphones" where the port is "Built-in audio."  Then click on "Input" and select the USB choice.  Now record a track and you can hear it being recorded through your speakers (or headphones).  When it's done recording and after the software transfers it to iTunes, you can play it again through your speakers without going to the preferences panel.
Dec 25, 2008 | ION Audio iTTUSB Turntable
Magnavox recorder
you casn look to see if you have a input on your remote and hit that to see if you can see something else
Mar 15, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Recording from a Digital Source (computer)
Your computer audio output is definatley digital, yes? If so, make sure it is set to 2-channel PCM digital output, not 5,1 Dolby digital surround sound output. Auto / manual on the unit is for track marks to be inserted during recording. If you google the manual is out there or I can email it.
Jan 15, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Only recording 59 minutes in LP mode
My WS-recorder did something simular to me. I hadnt used it for a while then it would only hold about 20 min. of recording no matter what record mode I selected.....so..... I held down the menu/folder button to get to the menu "mode". Press the FF to scroll through until you get to "FORMAT". Press Play and the screen will show "NO"...press FF to chose "Yes" it will ask you "are you sure" press FF to say "YES" then play to make it reformat. It hangs out for a couple of seconds then after that I have my regular 4 hours of record time back. ***** I would make sure I had downloaded all my info off the WS-100 BEFORE I did a re-Format.**** I dont know why it worked, but it did. I like this little recorder and Im glad to have it functioning properly again. The tinny/echoey sound could just be the environment you are in. Even how close or far it is from the subject...how many people are in the room....if a fan is on in the room....This little thing isnt super high quality in its play back mode....hook it up to you computer speakers and you will like the sound much better. Good Luck.
Jul 22, 2007 | Olympus WS-100 Digital Voice Recorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Tascam Dp-02cf Digital 8-track Recorder Logo
163 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
