Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the internet light will not light up and on the 'log in' page through the set up bit shows "internet not connected in red. I plugged my old router in and all works fine connecting to the internet. Any help is appreciated. Thanks
  • freestones Mar 12, 2011
    I am not at work at the minute but it is a speed touch router, and my ISP is Daisy communications (It was with Eurotel)
  • Gateway Master
  • 3,606 Answers
I cannot connect my Belkin - ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Posted on Mar 12, 2011
Connection to internet
To make an Internet connection 1.Open Network Connections 2.Under Network Tasks, click Create a new connection, and then click Next. 3.Click Connect to the Internet, and then click Next. 4.Choose one of the following:
• If you already have an account with an Internet service provider (ISP), click Set up my connection manually and then click Next. • If you have a CD from an ISP, click Use the CD I got from an ISP and then click Next. • If you do not have an Internet account, click Choose from a list of Internet service providers (ISPs) and then click Next. 5.From your choice above, click one of the following:
• If you are connecting to your ISP using a standard 28.8 Kbps, 56 Kbps, or ISDN modem, click Connect using a dial-up modem, click Next, and follow the instructions in the wizard. • If your DSL or cable modem ISP connection requires a user name and password, click Connect using a broadband modem that requires a user name and password, click Next, and then follow the instructions in the wizard. • If your DSL or cable modem ISP connection is always on and does not require you to type a user name and password, click Connect using a broadband connection that is always on, click Next, and then click Finish. Use the CD I got from an ISP
• Click Next, and then click Finish. Insert the CD provided by your ISP and follow the instructions. Choose from a list of Internet service providers (ISPs)
•To create an Internet account using MSN Explorer, click Setup Internet access using MSN Explorer (U.S. only), and then click Finish. Follow the instructions in MSN Explorer. •To choose an ISP, click Select from a list of ISPs, click Next, and then click Refer me to more Internet service providers. In the Internet Connection Wizard, click Create a new Internet account, click Next, and then follow the instructions in the wizard.
Feb 14, 2017 | Internet Computers & Internet
Can't set up Belkin 54g Router with MTNL broadband
Samay,
You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds.
You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
Mar 17, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
Why can't my second laptop connect to the internet?
ring your ISP internet sevice provider get them to check your modem for internet access online
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
Jan 07, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
PLease help me. Belkin belkin 7bc1d7 is looking for the isp username and password. I called the isp and was told no username is needed to connect it. please help I dont know what to do
The only time you don't need a user name and password to connect to your broadband/adsl company is if they supply your phone/internet/tv by cable rather than by the telephone line. If this is the case, you would have a modem supplied by the company and you would simply plug your pc/router into this.
If your internet comes down your phone line, you would normally need a user name and password. Only they can tell you what it is.
Dec 22, 2010 | Belkin Computers & Internet
Belkin 54g Wireless DSL/Cable Router (DHF5D72304): Im trying to hook my wii up to the internet and it...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings change channel type to 3 or 6 or 11 and save so you get better signal.
Then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 17, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cann't get my wireless router to work,don't understand how to config the router.
HI helock,
This is a step by step instructions:
Note: It is recommended that you configure the Wireless Router from a wired
computer.
1. Open your web browser, type http://192.168.10.1 in the Address bar, and then press Enter.
2. Enter the User Name and Password, and then click Log In. By default: User Name: admin Password: admin
3. The Wizard will automatically appear. Click Wizard if the Wizard does not automatically appear.
4. Click Next.
5. Select your Time Zone and then click Next.
6. Click Next. Note: Do not change default settings unless it is conflicting with your existing hardware.
7. The TEW-432BRP will attempt to auto detect your Internet connection. Follow the wizard instructions and continue on to step 9.
8. This screen will appear if the TEW-432BRP is unable to auto detect your Internet connection. Configure the settings based on information provided by your ISP.
9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection type may have different options.
10. Click Next
Note: It is recommended that you enable encryption on the wireless router. Please refer to the User Guide on the User's Guide CD-ROM for information on
setting up encryption on the wireless router. 11. Click Restart. 9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection
11. Click Restart
12. Click Close.
13. Wait 30 seconds while the router reboots.
14. Verify that the following panel lights are on: LAN, WAN and WLAN.
15. Open up your browser and enter in a URL (e.g. www.trendnet.com) to verify that you have Internet connection.
Your configuration is now complete.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Sep 14, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Additional Information: these parameters before i was given from my isp. it worked and then after about a week I pressed default restore factory settings and now i cant connect to the internet!!! I have...
first of all you need to create a new connection follow these steps :Start-Connect to-Show all connection -create a new connection-connect to the internet-next -set up my connection manually-connect using a broadband connection that requiers a user name and a password-next here write the ISP name-next here introduce your user name and password that your ISP give it to you. then connect and you should have internet.
Jan 18, 2009 | Computers & Internet
When trying to connect device the isp name not given
That is common.
Follow the manual installation instead of the Wizard -
All the information you need and is downloadable from Belkin for this model :
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Jun 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin 54g 2.4 ghz wireless router model # f4d7230-4
Hi, Instead of using the softwae disk, try going to the router's config page,
Connect your computer toi the router using the ethernet cable that came with it
then click here http://192.168.1.1
the usename is admin and the password is password
Use the basic setup wizard in there to input your isp username and password
Feb 22, 2008 | Belkin (F5D72304F5D7010) Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
236 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
