Question about Indesit Washing Machines
The machine is indesit 1wme126 .the problem is 2 lights are flashing the timer led and the stain led it wont let me reset the programme
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
SOURCE: indesit washing machine, wil103
Sorry, meant to add, if you switch the machine off at the mains once you've cleaned out the filter (bottom right corener, front of the machine, behind a plate), leave it for 2 or 3 hours and plug in again, sometimes it works.
Mine worked again the first three times, but I think this time it's had it and it's engineer and pcb time.
Posted on May 13, 2008
blueextc3221
  • 15935 Answers
SOURCE: Indesit WIL153 Door lock LED flashes with 2 other LEDS
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: washing machine fills then programme timer just keeps rotating
It appears your drive belt/coupling has failed in this instance.
Posted on Sep 16, 2010
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Aug 12, 2007 | Indesit W 123 Front Load Washer
I have an indesit wil133 .when one wash finished,the red flashing light came on ,so i could open the door,but also the delay timer & stain remover lights were flashing. now when i try to put another...
I would go to the manufactures website and download the user guide and look in the trouble shooting guide or I would check the water pump to see f there's not an obstruction in the pump preventing the pump from emptying the drum completely as if the water sensor is not telling the machine its empty therefore it cant start again
Jan 17, 2018 | Indesit W 123 Front Load Washer
I need to reset my delay timer on my wil133
how do i reset my indesit wil 133 machine as it wont start on any programme
Nov 27, 2009 | Indesit W 123 Front Load Washer
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Nov 07, 2007 | Washing Machines
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
