Question about Niles SI-1230 12-Channel Amplifier
My SI-1230 was not working on channels 5-6 and 11-12. I opened the amp and replaced the fuses on those channels. Now the fuses blow immediately on channels 5-6 and the red protection light is on constantly any ideas?
  • David Dunn
    David Dunn Mar 12, 2011
    Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
    Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
    You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
    If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
    If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
    Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
  • Niles Master
  • 5,056 Answers
Chances are the main transistors or whatever powers channel 5 and 6 have shorted out. Fuses blow like this when there is an overload and these power types do that a lot. If it uses transistors, then a ohm meter will show them up quick. Because it will be just like you have touched the test probes together when you put them on the terminals, with the meter on the 1K setting. For the reason these parts are just acting like pieces of wire instead of doing their job.
Posted on Mar 19, 2011
I am having trouble with my Niles Si-1230 amplifier going into protect mode after turning it on
Apr 04, 2011 | Niles SI-1230 12-Channel Amplifier
My Phoenix Gold MX 1230 12 channel amplifier 4 mode buss system keeps blowing the power fuse.
When any amp blows the fuse like this suspect an overload in either the power supply or main amp sections. Most likely caused by a sem-conductor that is acting like a piece of wire. Chances are it will be one or more transistors on the heat sink that's gone.
Mar 02, 2011 | Phoenix Gold MX1230 12-Channel Amplifier
I have a problem with my uniden cb with nitro 300a amp. The amp keeps blowing fuses immediately when I turn it on and I do not know how to trouble shoot the problem. Any help will be greatly appreciated.
hello is it the fuse along the cb line or the amp line if its blowing on the cb line you will need to get a 5-7amp fuse or even 10amp to be safe ,do the same with the amp this should cure the problem
Oct 29, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Fuse 42 radio system blows immediately after
Does fuse blow as you switch radio on/or radio still off
Either way ,remove radio,check connections for damp ingress
To remove radio go to fitaudio.com
Jun 19, 2010 | 2001 Volkswagen Beetle
Fusses on channel five and six blown can't read the rating any ides????
If the fuses on the other channels are good, try replacing the bad ones with that type and rating (assuming there are fuses on the other channels). My experiance suggest they should all be the same, as they are dealing with the same power levels roughly.
May 21, 2010 | Niles SI-1230 12-Channel Amplifier
I have 6 speakers connect to my Niles 1230. The 2
First, change them to a different set of channels to rule out any problem with the amp. Next, pull the speakers, depending on the manufacturer, if their older than 1 year they may be blown. If you can pull the grill off the speaker, do so and examine the surround. If it's rubber or plastic, it should be ok. If it's foam or paper, chances are it's bad. If you still have a problem, post a comment and I will help you troubleshoot some more.
Jul 07, 2009 | Niles SI-1230 12-Channel Amplifier
Fuses
mcm electronics should have them
Apr 03, 2007 | Niles SI-1230 12-Channel Amplifier
Niles SI-1230 12-Channel Amplifier Logo
403 people viewed this question
Top Niles Audio Players & Recorders Experts
 Grubhead
Grubhead
Joseph Hoffmann
Rob
Rob
Are you a Niles Audio Player and Recorder Expert? Answer questions, earn points and help others
