Question about Kenmore 96610 / 96611 / 96612 / 96614 / 96619 Electric Kitchen Range
What temperture should be used to keep food warm in my Kenmore oven, model 790-9611? Thank you
  • 22 Answers
HI, my electric stove has a warm setting and it is 170 degrees.
Posted on Mar 12, 2011
How to fix kenmore f 3 code?
f3 code is the code for the oven temperture sensor that control the oven temperture need be replace ok
Dec 13, 2017 | Washing Machines
Why is it that the power is controlled by the warmer switch
there's a relay that is controlled by timer circuit that cycles power to the element at a certain rate to keep food warm......asuming this is an electric oven......Regards, meder's tv service....please rate......thank you for using FIXYa
Oct 10, 2011 | Ovens
Refer not cold, freezer is?
http://www.managemylife.com/mmh/owner_manuals/16224/KENMORE-Bottom-Mount-Refrigerator-L0306154?brand_name_search=73503
go to the troubleshooting operation food temperture appears too warm. if follow step by step no work. please check the evaporator coil. if it cover by frost or ice. i am sure the heat element or defrost thermostat is bad
Jan 10, 2011 | Kenmore 73503 Stainless Steel Bottom...
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
Kenmore 1200 watt sparking when warming empty plates
Unless specifically stated in the manual, you shouldn't use the microwave for warming plates. That is not it's intended use.
I suspect the microwave circuit has failed in some manner.
Reply the specific Sears model number (in the form xxx.yyyyyyyy), and I can help further.
Jan 23, 2009 | Kenmore 63252 Microwave Oven
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 96610 / 96611 / 96612 / 96614 / 96619 Electric Kitchen Range Logo
113 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
