Question about Kenmore 24 in. 16039 Built-in Dishwasher
The soap isn't dissolving and it's not cleaning my dishes. It seems that the water isn't getting on the dishes
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 01, 2011
Whirlpool wdf310paa not cleaning dishes
Check water supply. Saddle valve failure can restrict water flow. DW
Apr 12, 2014 | Whirlpool Dishwashers
Dishwasher does not dissolve soap
If you have hard water, use only a little bit of soap. And you will probably need to add a rinse agent too. The government recently outlawed phosphate in detergent - now most detergents don't clean very well and don't dissolve either. This map shows the hard water regions in USA:
http://www.citriclean.net/why-citriclean/
Mar 16, 2013 | Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Kenmore 24 in. 16039 Built-in Dishwasher Logo
47 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
