Machine beeps continuously and display gives an E90 error code. What is wrong?
    Scholar:
  • 158 Answers
If this is a Zanussi washer then E90 indicates a communication error between the interface board (control panel) and the main circuit board. Unplug the machine from the power! and take the top off the machine, if you stand in front of the machine on the left side you should see the main circuit board along with a blue multi-wire cable going from it to the control panel (interface board). There is most likely a poor connection at one end or the other or maybe even both. This will generate an E90 error code. You need to remove the control panel by removing the screws located behind the soap drawer and also the plastic clips located along the top rail, disconnect the blue cable from each board one at a time and then plug back in making sure to firmly seat the connectors. These can become loose from miniscule vibrations from the machine operating. Put everything back together plug back in and it should work.
Posted on Mar 12, 2011
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
    E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
    Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
    After that the display will show one of the following errors that are more precise:
    E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
    E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
    E94 - Incorrect configuration of washing cycle.
    E95 - Communication error between microprocessor and
    EEPROM. Posible causes: Electronic board faulty.
    E97 - Incongruence between programme selector and
    cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
    Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
    Dado
    Feb 12, 2015 | Electrolux EW1000i Front Load Washer
    I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
    E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Basic Reset
    One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
    Feb 26, 2014 | Frigidaire Washing Machines
    E90 and continual beeping
    Hello - I am happy to assist you. However, could the error could possibly be an E9? If so, E9 on an All Refrigerator typically indicates a shorted thermistor. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
    Jun 08, 2013 | Frigidaire Refrigerators
    E90 error
    If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
    Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
    Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    Washing machine displaying E90 error
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Dec 12, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    My zanussi will not turn on at all.
    If you give the facia a tap the display may come back on. You may then get an error code E90 being displayed. Either way you will require a new user interface pcb.
    Nov 18, 2008 | Zanussi FJS1225W Front Load Washer
    Electrolux 1087 E90
    call frigidaire for factory service or have the dealer replace it
    May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
    Electrolux 1087 E90
    When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
    what can i do ?
    Sep 15, 2007 | Electrolux EW1000i Front Load Washer
    Washing Machines Logo
    251 people viewed this question
    Top Washing Machines Experts
