Question about Refrigerators
We were moving the fridge and the power cable was ripped off.
  • bentravis Aug 01, 2008
    Hey,
    cheers,
    but the whole thing has torn off, it was only held on but these aigator clips.
  • 828 Answers
If any of the old cord still remains it is not a hard job to spice in a new cord.
Posted on Aug 01, 2008
Moved fridge and heard a pop and saw a spark where the cord goes into the panel at the bottom on the back.
You may have damaged the power cable causing it to arc to ground. Shut off the breaker to the fridge then unplug it and call a repairman.
Jun 28, 2015 | Refrigerators
I need to know how the power cord is connected to the connection box in the back of the fridge ( green, brown, blue cords) model ksr390
220 volts!!! be careful get a schematic or call a pro this is NOT a job for a novice you will expose yourself to dangerous voltage
Dec 12, 2013 | Bosch Refrigerators
Cpu fan is locked
The CPU fan if no longer spinning. To confirm this, you need to open the RIP cage cover. If the CPU fan is not moving, check if the CPU fan cable is properly connected to the J-Fan1 on the RIP board. If it not, please connect it properly. If it is connected, you will need a replacement RIP board.
Aug 01, 2012 | Lexmark X502N All-In-One Laser Printer
My fridge freezer has stopped working
try to check from the compressor cable connection if there is a power on it, after that check if the overload termistor is still working, if it working maybe the deffrost timer is broken..
May 19, 2012 | Refrigerators
Whirlpool refrigerator ET18GKXHW0 NW power cord ripped out
The refrigerator should have a wiring diagram. Look in the grill on the bottom of the front of the refrig. Pull that grill off and a lot of times they are in there. Sometimes thay are taped to tha back also. You can buy a wiring diagram just like any other part from Whirlpool or sears parts center.
Sep 10, 2009 | Refrigerators
Too warm both freezer and fridge recently ice cubes melted when opened a lot.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Admiral Refrigerators
My Daewoo FRS2021IAL has a warm fridge
Aug 26, 2009 | Daewoo Refrigerators
Samsung model rs2577sl. fridge side not working
Aug 25, 2009 | Samsung Refrigerators
My front driver side power window is not working. One Minute it wont roll down but I can hear the motor. Then the next minute it was working fine. now the window is lose and i can move it up & down by...
you have to replace the window regulator reason why is because the cable ripped which would cause the motor to work without moving the window up or down .. regulator is the cable and the rails were the motor makes the woindow move up and down on. you have to replace it.
Aug 14, 2008 | 2001 Chrysler PT Cruiser
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
