Question about Savin Office Equipment & Supplies
Where is the waste toner bottle in th savin c2828?
  • 34 Answers
It is to the left of the number one paper tray, hidden behind the small door. Loosen the screw from the top and the door swings out. I hope that helps.
Posted on Mar 12, 2011
Savin 2406wd how to change waste toner bottle
Do not attempt this , call a qualified tech, the drum can easily be damaged during this operation
Aug 14, 2014 | Savin Office Equipment & Supplies
Where is the waste toner on savin 4051 sp
it's behind the front cover - lower right side...unlock the push/pull snap and side the bottle holder & bottle out of the front of machine. empty and reinstall.
Apr 08, 2014 | Savin 4051 Sp, Ricoh 2051 Sp, Copier W/net...
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
Savin 2400WD, where is the waste toner bottle?
You have probablly figured it out by now but its behind two panels on the lower right of the machine.
Jun 15, 2010 | Savin Office Equipment & Supplies
WASTE TONER BOTTLE REPLACEMENT FOR SAVIN 2400WDP
Lift the upper section and on the right side take off lower right cover. -Carl
Jun 08, 2010 | Savin Office Equipment & Supplies
Self test says 'check waste toner box'
It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
May 21, 2010 | Kyocera FS-C5030N Led Printer
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
274 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
