Question about HP DeskJet 920c InkJet Printer
Just changed colour cartridge and it is only printing in shades of red. Any idea what the problem is?
  • 114 Answers
Cartridge problem colour maintan in program
Posted on Mar 12, 2011
When i am printing anything it is printing with a shade of pink
Hi, You are getting a pink shade in your printouts because your colour ink cartridge is running out of ink, it is probably time to change the colour ink cartridge.
Apr 12, 2011 | Kodak ESP 5 Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
I have just fitted new cartridges although it was only the colour one which needed renewing I thought! However it wuld only print out in red/pink shades so I changed the black cartridge to be on the safe...
I have personally encountered similar problem in my work. There is no problem with your printer, No need to go to your suppliers yet.
Sometimes when either of the inks overflow at the nuzzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning that yellow printing red back to printing truly yellow. Bring out your colour cartridge. Peel off the seal covering top. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nuzzle. Clean off the ink. (At the nuzzle do not rub only dab). Now press a piece of folded tissue to the nuzzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 06, 2009 | HP PSC 2355 All-In-One InkJet Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Only prints red - changed color cartridge, still only prints shades of red. tried to clean and prime and still only prints red
did you cleaned golden contacts on print head and cartridges with alcohol? if no, try it, other option is, that new cartridge is bad, I had similar problem, bad shades of colors, replaced cartridges and it works now
Jul 10, 2009 | HP DeskJet 882c InkJet Printer
Changed all 4 cartridges, yellow, red, grey not printing. Only blue & black print
Sounds like most of the color lines (the "cables" between print head and cartridges) either have clogged ink in them, or air bubbles. Try the cleaning process found by pressing Ink Management and then Menu/Set twice. After the test print sheet is printed, answer the question(s) in the display and print up to five test prints by answering the questions.
It should solve the problem, but if it doesn't, you should perform a heavier duty purge found in the service mode.
Jun 02, 2009 | Brother MFC 420CN All-In-One InkJet...
HP psc 2110xi color printing problem
The printer head may need to be cleaned. You can buy a cleaning kit for the head.
May 08, 2009 | HP PSC 2110 Color Printer
Printer prints documents with gray-shaded background
check the mode of printer is i grayscale or in colour mode. bye
Jan 30, 2007 | Dell 922 All-In-One InkJet Printer
Colour faded
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
HP DeskJet 920c InkJet Printer Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
