Question about Garden
I'm changing the cutterhead bearings in a Mclane Lawn edger. Do I need to pack the housing with grease?
  • 718 Answers
Was it packed with grease when you took it apart??? If there are gears there lubricate yes! Good Luck..
Posted on Mar 12, 2011
Need stihl fs45 bearing housing
contact a stihl dealer
Sep 12, 2016 | Stihl Garden
What can be making my edger turn off right when it sounds as though its going to start?
A faulty on off switch can cause this.spark plug foulage.fuel blockage.loose spark lead.broken power feed to spark.hope this helps
Aug 14, 2014 | McLane 3.5 HP Gas Edger & Trimmer...
My weedwacker does not spin
Not much info in the question. You may have organic matter wrapped tightly between the spool housing and the shaft. To fix, removed the spool housing to acess the weed stems, grass or other stuff that could be tightly wrapped up in the shaft. If yours has the gear housing you should remove it and clean it inside as well. It will have stuff wrapped in the lower bearing so tight you may have to replace the bearing. Use wheel bearing grease when re packing gears.
Apr 16, 2014 | Craftsman Garden
I need a complete bearing housing assembly part number 153598
the bearings can be replaced without replacing the housing,snap rings hold them in place,numbers are on the bearings.match them up at a napa parts house,. a lot cheaper that way .
Nov 29, 2013 | Garden
What kind of oil to use for mclane 801-3.5RP edger
Gene you can use a standard lawn mower oil in any small machine like yours
Oct 20, 2013 | McLane Walk Behind Edger 801-3.5RP
Can not start garden edger made by mclane
O-kay engine and motor are the same. I'll have to do some checking on this one and I'll get back to you.
Oct 02, 2009 | Garden
I just went to start up my older model McLane gas edger. Started up without a problem until the spark plug suddenly flew out. I assume I must need a new spark plug but is there more?
i would check the thread where your plug screws in it can be fixed with what they call a helicoil thread repair kit hope this helps.
Jul 02, 2009 | Garden
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
